Moved my turbo Formy...
Old 04-01-2007, 03:26 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Moved my turbo Formy...
I took off my Bogart/28W's and put on my Bogart/325 DR's. Seem to fit about the same.
I cleared off all the junk on the car, and moved it to one of my other garages, in preparation for a short trip to Speed Inc. to look over stuff and then off to the track I go.
My wife took some vid, I'll hopefully upload it tonight.
Old 04-01-2007, 04:33 PM
Motorboater
SilverGhost's Avatar
wow thanks for the update john, gripping story.
Old 04-01-2007, 05:43 PM
TS6
TS6's Avatar
Yeah, I'm spellbound.
j/k
Old 04-01-2007, 05:44 PM
98turbls1's Avatar
Getting ready to better that 9.8 looks like... Is there anything different that you're going to be doing this year versus last year??
Old 04-01-2007, 07:01 PM
Big Mike's Avatar
Man you ******* guys are ruthless towards PSJ!!
I hope John goes 7.90's just to put it in everyones face!
Old 04-02-2007, 12:19 AM
y2khawk's Avatar
Old 04-02-2007, 12:41 AM
2002/Black/SS's Avatar
hahahahahahaha thast so funny
I cleared off all the junk on the car, and moved it to one of my other garages.
ooooo mister i have two sets of bogarts and a bunch of garages, u trying to make us jealous???
Old 04-02-2007, 06:53 AM
Big Mike's Avatar
Originally Posted by y2khawk
STOP IT!!!!!!!!
Old 04-02-2007, 07:18 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
john do you still need a cheapo rear?
Old 04-02-2007, 08:29 AM
LS1Tech Co-Founder
Nope, found one.
I'm not changing anything, I'm just going to "put 15psi in the tires and launch at 13psi" and run betterer.
Seriously, I am going to launch better like Matt and other folks told me how to, and the car should do markedly better next time out. I'm going to run on slicks though.
Old 04-02-2007, 08:48 AM
Senior Member
Country Boy's Avatar
Cant the Mustang dyno simulate the 1/4 mile?
Old 04-02-2007, 09:28 AM
LS1Tech Co-Founder
Looks like you want a custom pink moderator color Carl.
I wonder if some veteran turbo racers could maybe chime in quick about how they stage? So I recall seeing Matt bring up the revs at Thunder a few years ago, was Matt actually in boost before he even tripped the first beam?
Old 04-02-2007, 09:43 AM
bowtieman81's Avatar
This thread is great; you guys are pretty brutal on poor PSJ but it does make for some good laughs.
Old 04-02-2007, 09:45 AM
Senior Member
pink would rock!
Old 04-02-2007, 10:02 AM
Moderator
FANTAZ28's Avatar
I'll be a good friend..... I'll drive!
even tho last time i drove that thing i thought the rear end fell out.
Old 04-02-2007, 10:36 AM
LS1Tech Co-Founder
I'd like to hit Byron real soon.
Old 04-02-2007, 10:47 AM
MIGHTYMOUSE's Avatar
-> move to wheels and tires section, i will then ask how the 28's fit if any banging/trimming was required of if you have adjustable lca's
Old 04-02-2007, 10:58 AM
Brains's Avatar
Staging with a turbo car (from my limited experience) is simply an exercise in footwork and in your case transbrake button work. You don't want to stage before you start building boost, or your *** is going to get tree'd. Once the turbo is spinning enough to build a lb. or so boost, it'll come up pretty quickly to your launch boost. So do the burnout, sit on the prestage beam, two foot it on the footbrake until you get a lb. or so, then creep forward until the stage beam lights. Then hit the tbrake button and mat the pedal.
We REALLY need to get speed to put a tree in front of the dyno so you can practice..
Old 04-02-2007, 11:55 AM
Ed @ Late Model Speed's Avatar
that's funny, but I agree with Brian, and launch almost indentically, if you can hold a couple pounds when you launch, it will drastically improve your short time
Ed
Old 04-02-2007, 12:01 PM
NA$TY-TA's Avatar
Ill try that on my next outing...... all of it except the tree on the dyno part LOL
Quick Reply: Moved my turbo Formy...
