4l60e valvebody
Old 04-01-2007, 11:48 PM
MENACE's Avatar
Default 4l60e valvebody
I have the 1870 code in my 97 chevy 1500 4x4. From what I have read I need a valve body rebuild. The tranny is only like six months old. It is a megamax tranny, don't laugh. I got screwed like a lot of other people. Well I own it now so I better fix it. Can I buy rebuilt/new valve bodies? How hard is rebuilding what I have? I figure someone on this site will have the info I need. Thanks in advance.
Old 04-02-2007, 09:00 AM
LS1Tech Sponsor
performabuilt's Avatar
Actually Transgo and Sonnax offer a kit that will solve that issue without to much effort .
sonnax the easier of the two 77754-03K
Transgo Kit: 4L60E PSK
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-02-2007, 10:29 PM
MENACE's Avatar
Will the somax kit fix the hard 1st to 2nd shift. I forgot to mention the truck will not go into OD as well. With the shifter in D the truck will shift really hard from 1st to 2nd then normally into 3rd then nothing. Whats the deal?
Old 04-02-2007, 10:40 PM
LS1Tech Sponsor
When code 1870 sets line is sent to max by the PCM and 3-4 shift is disabled. this will cause the very hard shifts because the line is maxed, The PCM sees the converter clutch commanded to engage but then detects excessive slip ussually this is due to sticky regulator valve that sets right next to the pwm solenoid or a bad pwm solenoid.
Then the PCM it thinks theres something slipping and then as I said raises the line presure to max and disables lockup and fourth gear,
If you get the sonax kit and a new PWM solenoid you should be fine if everything else about the transmission is working ok.
Code 1870 is a common issue with the 4L60E
__________________
Call 888-744-6542
Old 04-02-2007, 11:10 PM
MENACE's Avatar
Do you guys sell these parts? If not where is a reliable source to buy them?
Old 04-02-2007, 11:28 PM
LS1Tech Sponsor
PM sent
__________________
Call 888-744-6542
Old 04-03-2007, 09:30 PM
MENACE's Avatar
What is the difference between these two parts
http://www.transmissionpartsusa.com/...-07775404k.htm
http://www.transmissionpartsusa.com/...-07775403k.htm
Old 04-03-2007, 10:12 PM
LS1Tech Sponsor
Thats a good question I see some minor differences in the way they are made, but the both do 93 up , Perhaps you should call sonnax there number is on there website and they have very good technical support
__________________
Call 888-744-6542
Quick Reply: 4l60e valvebody
