will i run slower??
Old 04-02-2007, 10:51 AM
dameter21's Avatar
Default will i run slower??
I'm getting a vig 3600 installed and I was wondering if I'd run slower because I only have basic bolt ons. but I do spray 100 shot at the track.
2000 T/A a4 lid/filter, stock catted y-pipe cut out, dry kit 100 shot. 10.5 et streets.free mods. pro tune.
Old 04-02-2007, 10:59 AM
mattraypharbor's Avatar
lol YOUR gonna go faster if you can hook!
Old 04-02-2007, 12:52 PM
c0ncEpT's Avatar
If you can hook I say you could go near .5 faster NA and who knows what if you can go if you hook the n2o out of the hole with out breaking anything!
Old 04-02-2007, 02:40 PM
if your runing a stock tranny and rear say goodbye to them if your planing on sprayin out of the whole and if your trannys stock say goodbye alltogether...
Old 04-02-2007, 05:09 PM
BlackHawk T/A's Avatar
Don't worry about the rear end. People really over-exaggerate how easy it is to break with an automatic. Do a good cooler and TransGo HD2 kit and the transmission should be fine.
Old 04-02-2007, 05:37 PM
waterbug1999's Avatar
If he hits that 100 shot out of the hole and hooks it, there is a good chance of the rear breakin or the drive shaft. The tranny will go soon after!
I am on my 3rd one in a little over a year. 1st one was the stocker which went 100 miles on N/A after the H/C build. The Stage IV trans from Rock on went 1000 miles later and 3 bottles with the 100 shot and no track passes. Now, FLT stage V is on its way.
My built 10 bolt has survived 1.54/1.56 60' last year with no issues. But, it is built up a little.
Old 04-02-2007, 09:12 PM
dameter21's Avatar
yeah I know I'll go faster.lol.. I guess I stated it wrong.here I go again off the gas will it run like ****. reasoning little mods and big stall. I heard the vig 3600 hits just like a Yankss 4000 if not harder.
Old 04-02-2007, 09:15 PM
dameter21's Avatar
now I'm gonna only do 75 shot out of the hole.. you guys are scaring me.lol..
it's all a gamble tough I've seen stock 10 bolts take several 200 shots on slicks. I mean look at some of the guys in the 10's. but it is just on borrowed time I guess.
Old 04-02-2007, 09:40 PM
I know my car on motor has a 11.4 in it now that the tranny is not boucing off the rev limiter.. Also, I will be spraying it in 2nd on up.
But, if I get the 9" by the time the tracks open, then I will be sprayin that sucker out of the hole for sure. I got a set of skinnies bought and payed for form SJM which are the Bogarts bolted RT's so that ought to lighten the front up.
Good luck Bro!
Old 04-02-2007, 09:44 PM
dameter21's Avatar
Thanks
