I need help....1969 camaro LS series motor
Old 04-09-2007, 10:05 AM
burnout2006's Avatar
Default I need help....1969 camaro LS series motor
I want to make as much power as possible on PUMP GAS!!! I want to RETAIN Air Conditioner! THis will be a weekend driver. What turbo or procharger do u recommend for me!!! thanks
Old 04-09-2007, 10:25 AM
bump bump bump
Old 04-09-2007, 10:48 AM
NassyVette's Avatar
You can do whatever you want, all it takes is money. Do some research and find out what you like.
Old 04-09-2007, 12:17 PM
LS1NOVA's Avatar
Are you sure you want max power on pump gas? Twin turbos are going to give you the most power if its an all out setup. Do some searching on here.
Old 04-09-2007, 12:22 PM
JMBLOWNWS6's Avatar
I would not risk that kind of $ on pump gas. I always just buckup and pay for at least 5 gallons of MS109 and fill the rest of the tank with regular 93. Its a good insurance policy.
Old 04-09-2007, 09:29 PM
So what would you BUILD?
Old 04-10-2007, 04:58 AM
EPP
EPP's Avatar
We are finishing up on installing an LS2 into an original '69 Camaro Z28. We should be done with it today or tomorrow. It looks to me that the ATI ProCharger for the GTO's would be the blower to start with. There is not enough room for the F Body blower, from what I can tell. Check out this RX7 that has an LS1 in it, in which we used the ATI ProCharger GTO kit.
http://www.exoticperformanceplus.com...Car.php?car=22 Bob
Old 04-10-2007, 07:21 AM
BLNLS1/RX7's Avatar
They did an excellent install for me(rx7) and the results 563RWHP.The whole crew at EPP know there stuff and when it comes to Pro Chargers nobody can come close to there expertise in North America.
Old 04-10-2007, 11:44 AM
LS1NOVA's Avatar
Forged 408 with twin 70's.
Quick Reply: I need help....1969 camaro LS series motor
