Car over heated allot, did it hurt it??
I was driving in the cold *** rain the other night, my temp gauge came up too fast for it to be real in my book, i called it bluff, i kept driving till i hit a fuel station, checked it and it was boiling its *** off, i refilled it due to being low, it had a hose rubbing the PS pulley and was spraying out, i limped it back home but it still was past 260!!! Think it hurt anything??? I will replace the hose today but i started it and it sounds fine, think i hurt anything, if it was a ford i would know i was mucked, what do you guys think??? Im screwed with warped heads and the works or i might be ok?
Take the oil cap off and check to make sure you don't have a coolant/oil froth in there. When I blew a head gasket on my old firebird, the car drove ok it just missed a little bit, I thought it was the damn coil packs again. This happened to me months after the car had overheated driving in the mountains.
Originally Posted by ZONES89RS
Thats what i figgured, it didnt run like it had a cracked block or heads so i figgure i will find out after i replace the hose, fill it up and bleed the air out.
Well, everyone sais look at the oil, i know what it would look like i have sen it before, it still looks fine, i guess it is passing into the cylender, slow enough to not steam i guess...
when mine blew it slowly bled ino one of my cylinders..took a while and then once the gasket completely went it screwed the motor in a matter of minutes..the oil is gonna give you a good clue but not always definite...took a while for mine to show in the oil since it was a slow leak
How many miles are on it? When my car overheated, I blew the head gasket by the #7 cylinder quick. I had around 135k or so for mileage. Everything looked great when I tore the top half of the motor off, except for the head gaskets, if it hadn't gone there, it was working on it in other places.
I would definitely keep an eye on it but I personally would jump to any conclusions yet. I would refill the coolant system, drive it a little, check the oil then see how she does.
Well i seen it was low again, i will fill it and drive it tomarrow, we will see, like i say, i am glad i have a set of vette heads lying around, are there any difference between the vette heads and the camaro heads??? I really am just glad to have a set that are not warped, i will port them and have a valve job done, think i will pick up 10-20 HP?
It has exactly 135K on the odometer.
