fuel cut 2 step
Old 04-09-2007, 10:10 PM
cablebandit's Avatar
Default fuel cut 2 step
efilive has a fuel cut 2 step buil into its custom oper. system. Any danger in using this on a tbrake for boost vs harlans spark cut?
Old 04-09-2007, 10:13 PM
black98ws6ta's Avatar
It doesnt sound very friendly to cut fuel and lean things out.
Old 04-09-2007, 10:17 PM
98turbls1's Avatar
Ouch!!! That is no way to treat your engine... I wouldn't do it.... The point of an actual two step is to cut spark and load the engine up with fuel which will spool the turbos... I don't know if it will have the same effect the other way around... Think about it... =)
Old 04-09-2007, 10:20 PM
gametech's Avatar
I've done it before with HPT, and the fuel cut limiter would not build boost and would not hold a steady rpm like a spark cut can. Instead of stuttering at a nearly stable rpm, it would hit the limit rpm, then drop over 100rpm, then go back to the limit, etc. And this was with the re-enable rpm set 1rpm under the cut rpm.
Old 04-09-2007, 10:35 PM
Rpm2800's Avatar
I would not cut fuel when using something that is designed to build more boost in the first place.
Old 04-09-2007, 10:46 PM
doesnt aem use fuel cut for its 2 step? thanks for the opinions...4 NO..0 YES
Old 04-10-2007, 07:19 AM
Jake@EPP's Avatar
AEM uses a large spark retard,
Fuel = Fire = boost!
Old 04-10-2007, 10:24 AM
7 Second Club
ty_ty13's Avatar
fuel cut = NO, NO
you can use a msd box for the lsx... it just cost you$$...$
Old 04-10-2007, 10:45 AM
LS1TECH Sponsor
DrTurbo's Avatar
No, you don't not use a fuel cut style 2 step. That is for N/A. For a turbo setup the point in the 2 step is to expel unburnt fuel into the runners and then ingnite for heat, which helps spool the turbo.
Old 04-10-2007, 01:37 PM
well i guess that settles that Ill be keeping my harlan 2 step and use that function in efilive as a valet mode
Thanks guys
Quick Reply: fuel cut 2 step
