General LSX Automobile Discussion Non-technical LSX related topics.
Ok how about spark plugs?
Old 04-10-2007, 03:02 PM
fccs's Avatar
Default Ok how about spark plugs?
What do you guys say for spark plugs for a 98 trans am? I've been looking at NGK ones maybe the vpower what would you guys say youve had the best experience with?
Old 04-10-2007, 03:13 PM
Jordan S.'s Avatar
If your car is stock just put A/C platinum's back in it.
staringback05's Avatar
ac delco iridiums...gapped at .050....
youll be fine....ive run them for 9k miles so far...still damn clean
Old 04-10-2007, 03:14 PM
bmxer8699's Avatar
x2 for the iridiums.. id never go with bosch... (SP)
Old 04-10-2007, 03:25 PM
Starz T/A 17's Avatar
TR55's Just regular NGK's ALOT of guys run those and they perform great, and there under 2 bux a plug
Old 04-10-2007, 05:13 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,794 Likes on 1,278 Posts
LS1Tech 20 Year Member
I'm using the NGK TR55s right now (gapped at .055), been using them for years with great results. But I plan to try the AC Delco Iridiums next. However, for the AC Delco Iridiums, GM says to leave their gap at .040, so that's what I'd recommend to do for a stock to mild engine.
I would avoid the platinum tip plugs. IMO.
Old 04-10-2007, 05:23 PM
BriancWS6's Avatar
NGK user here as well.
Old 04-10-2007, 05:25 PM
i like the NGK's but the plus for ac delco's is that the iridium holds up better then the copper of the ngk's......several hard open runs...and youll know what im talking about
Old 04-10-2007, 10:42 PM
BLKWS.6's Avatar
I checked my stock plug and it was loosely gapped at .057 (Did not want to WEDGE the guage in there with the fine-wire setup). Stock is .060. I bet mine was right-on had I tight-gapped it. It looked mint and I have 79K on them.
Old 04-12-2007, 08:55 PM
INMY01TA's Avatar
NGK TR55s, part # 3951
Old 04-12-2007, 09:05 PM
Sunset'01Z's Avatar
tr55's here but thinking about going w/ iridium next. car is a little rough sometimes, i think they might need to be changed.
Old 04-12-2007, 09:55 PM
sapper5000's Avatar
Does anyone know if the the ac delco iridiums come pre gapped or not?
Old 04-12-2007, 11:13 PM
hardcorebob's Avatar
NGK Iridium IX's gapped at .050 here and they are holding up great.
Old 04-13-2007, 02:48 AM
jbuerke142's Avatar
another vote for the tr55's
Old 04-13-2007, 07:54 AM
CJDZ24_Z28's Avatar
FU*K NGK!!!Even though they are a good plug,they're are made in JAPAN
AC Delco plats or Irridiums are great I'm currently using autolite double platinums
