Heads on procharger???
Old 04-12-2007, 02:46 PM
BorlaTA's Avatar
Default Heads on procharger???
I saw the other procharger head threat but i had a little different selection on heads. Plan on ati procharger next year and i want to do heads first. I was looking at afr 225cc or lq9 patroit heads. Which is better for my set up. Also what do you think i will get out of the power gains.
Thank you guys.
Old 04-12-2007, 06:35 PM
BorlaTA's Avatar
Anybody outthere???
Old 04-12-2007, 06:53 PM
Jake@EPP's Avatar
It really depends what the budget is? The afrs are pricy, but proven time and time again, the patriot is a all around awsome budget head that works great with FI and NA, for the $$ it is very worth it.
Are you planning on staying stock bottom end? If not then i would get heads, if you want only around 500hp then the stock heads are fine with 8psi with a ATI.
Old 04-12-2007, 07:19 PM
mikep2002's Avatar
Hmmm I like the sound of those AFR 205 with the 76cc chamber on a 346/347!!! Ever so tempting.
Old 04-12-2007, 08:35 PM
BorlaTA's Avatar
Difference between the afr 205cc and the 225??? Plus im on a stock bottom end.
Old 04-12-2007, 09:15 PM
Jake@EPP's Avatar
The 205s will have a better lower tq, while the 225s will sing up top.
Old 04-13-2007, 05:44 PM
BorlaTA's Avatar
So from experience which heads are better and what hp gains could i expect from them. Or if u perfer something eles put it down and why.
Thanks
Old 04-13-2007, 06:28 PM
BorlaTA's Avatar
What about some ls6 stage 2 heads.
Old 04-14-2007, 05:54 AM
EPP
EPP's Avatar
A very good and inexpensive head to use is the Patriot LQ9 Stage 2 heads, which will drop your compression ratio slightly. We use these heads up through 16 psi, past that amount of psi, I would go with a thicker head deck, such as what the AFR heads come with. Bob
Old 04-14-2007, 11:36 PM
SVC707's Avatar
AFR's 225.... 707rwhp @9 psi
Old 04-15-2007, 09:57 AM
Bad30th's Avatar
I went with West Coast Racing Cylinder Heads (WCCH) stage 2 LS1 blower heads.
Lowered the compression a little with the 71cc chambers (9.4:1 with my -4cc pistons), and they are CNC ported with their Stage 2 port job. Richard is very helpful in discussing your goals and picking out what you need, and it won't break the bank.
I'm making 740+ torque on 8.5psi and a 50 shot with an LS6 cam and shorty headers - on STOCK cubes. (Well, 1 more ci than stock, W2W forged 347).
Rob (Bad30th)
Quick Reply: Heads on procharger???
