Northwest Members WA, OR, ID, MT, WY, SD, ND
I need help (Ellis or Mark)
Old 04-12-2007, 07:41 PM
Daredevil_TA's Avatar
Default I need help (Ellis or Mark)
I posted this in the internal engine thread but i haven't been getting the answers i need so i thought i'd try the good ol' NW section. Anyway, im doing a H/C project for my car an i need to get gaskets, problem is i don't know where to get the ones i need. I ordered a set of Stage 1 LS6 heads from Patriot an they told me to use the gm graphite gaskets at .041 compressed thickness-(im raising the CR to 10.7:1) i then find out that GM doesn't make this thickness of gasket. So i thought i'd go with cometics but they don't have the bore size i need to match my heads-i need 3.905, I also need to know what other gaskets i need to do a heads and cam swap. does anyone know of a kit i can get with all the gaskets i need including the head gaskets? thanx in advance
Old 04-12-2007, 09:08 PM
WAHUSKER's Avatar
I'm using the Cometics, but my bore is 4.0......I really don't know off hand. Sorry!
I will say you don't "need" to replace the factory rubber gaskets on LS1s. I usually replace the water pump gaskets just because, but other than head gaskets you should be OK using the old ones again (provided they look good - not torn, etc)
Old 04-12-2007, 09:37 PM
Layn_Low_247's Avatar
Thunder Racing, or TSP. They should have what your looking for.
Old 04-12-2007, 10:12 PM
I checked TSP an they have cometics at .040 but thier at a 3.910 bore, why am i not able to find 3.905 anywhere? is the something im not getting here?
Old 04-13-2007, 12:08 PM
bump...
Old 04-13-2007, 12:16 PM
okay, thunder racing has the bore i need but its a .045 thickness, is this the compressed thickness they give you? or is that straight outta the package?
Old 04-13-2007, 10:05 PM
NWDragRacer's Avatar
.005 bore size or .001 in thickness is not going to matter even a little, except maybe if you were building an F1 engine.
Old 04-13-2007, 10:13 PM
TwoFast4Lv's Avatar
The 3.910s are fine
I get all my gaskets local or from SDPC2000.com
Old 04-14-2007, 02:25 PM
i see, i wondered about that-glad somebody finally came to the rescue, thanx again
Quick Reply: I need help (Ellis or Mark)
