I need a new Torque Arm..
I was messing around and went to back up, it wheel hopped a bit, so I stopped and started to take off. I had a friend with me so we were having a little fun, I hammered it and it went snap and I heard a little grinding, so I thought I dropped the Gears again..
I got under there and I saw this..
The Drive Shaft was rubbing on the Exhaust, and it's missing a Bolt, it's in the road somewhere..
Time for an adjustable Torque Arm..
Originally Posted by the_merv
Here is the new one I am looking at..
http://www.umiperformance.com/2203?category_id=45
i have that same piece with the loop...
very easy to install and it is a solid piece...
you will need the angle finder also.
Yea, a friend of mine has the Angle Finder. Looks like a nice piece, I can't run my X-pipe True Duals with my new setup, it will be the same as it is now. It will be a nice setup though..
****, slap my wrist and take my Birthday away..
I only built the whole Engine correct to break the Torque Arm that I had the 2 Bolts up-side down in..
I didn't figure there was a "certian" way, I see that now. Sometimes this is how you learn.
Break **** and upgrade..
Originally Posted by BsGreenZ
why were the bolts in the wrong way????
From the looks of it the bolt was missing for some time and the other was loose for some time. That will teach you to rush putting something back together.j/k lol
I am looking at this torque arm set up as well. I hear that make a bit more road noise but it would be worth it for better traction from hooking farther back on the car and lifting it more. You will need it with the power you get out of your new setup. Its to bad you can not run your x pipe with this but I think you might be better off with this set up anyways
