Generation IV Internal Engine - LS7 Fuel Rail fit's what Intakes?
View Full Version : LS7 Fuel Rail fit's what Intakes?
Ferocity02
04-18-2007, 09:27 AM
I've been getting a lot of questions regarding the LS7 fuel rail on non-LS7 manifolds. I actually don't know myself and would like to find out. Does anyone know if it will fit on the LS1/2/6/76 intakes? My concern would be injector height and bolt pattern. Thanks!
98blackSS
04-18-2007, 10:05 AM
Injector seating angle is different. It's around 5deg or so for the LS7 rail I believe.
Scoggin Dickey
04-18-2007, 10:24 AM
That's correct, the angles are different on the LS7 from any other rail....also the spacing where the fuel rail actually mounts to the intake varies slightly on the LS7 from the others.
Ferocity02
04-18-2007, 02:26 PM
Great, thanks!
Nasty N8
04-19-2007, 04:33 PM
We are in the process of making an LS7 billet rail should be done next week.
Nate
Stang's Bane
04-19-2007, 04:39 PM
Nate
I wonder whose intake you are using for mockup??????LOL
ss dave
04-19-2007, 05:28 PM
Nate, where have you been with this, I went with a Fast fuel rail to provide a flow- thru parallel system for my LS7. Because the stock injectors are small in height the fuel rail didn't fit. Changed to Bosch 44.5# injectors which provided the size to make the rail fit and system work. I'm glad to hear you are providing an alternative.
Nasty N8
05-22-2007, 02:30 PM
How did you get this to work the injector angles are completely different? Well we still can not get the stock injectors to fit as they are way too short our rail runs into the mounting hardware for the intake. But good news our LS7 rails are complete for the tall standard style injectors.
Nate
Stang's Bane
05-22-2007, 02:54 PM
Nate
Have any pics cough***mine***cough ?
ss dave
05-23-2007, 01:06 PM
Nate
tried your # but got msg mach. We took the injectors and fit them into the manifold and looked at the angles, spray pattern etc. Determined that none of the fuel spray ended up on a surface but would spray into appropriate space. Fitted the Fast rail with custom brackets and then used Katech O-rings. They fit without problems.
Chose the Fast rail for OD size and flow thru design. What is your rail size? That's a good price on the rails.
