ring and pinion interchangability?
will a 1987 monte carlo ring and pinion (im pretty sure its a 10 bolt, its stock anyway) interchange with my 1993 z28 ring and pinion witch is obviously a 10 bolt? a buddy of mine has 4.11 gears in his and we are talking about trading since i have 3.23s and he wants better milage, but i dont know if they are interchangable. i havent got to look under his car so i dont know if it is a 10 bolt for sure but im pretty sure it is, its got a 350 anyways if that means anything. i thought 4.11 were ford gears i didnt know chevy made them, but he might mean 4.10s. im thinkin the 10 bolts are identical from those years right?
cool, do you think it will kill my gas milage? i did the math and i should be running just under 2700 rpms @ 70 mph. im gettin about 18 city and highway as is, depending on my foot
depends on wat carrier it is. there r 2 different carriers for the 7.5 rear end. carrier 2 came out will cars with 3.23 and higher which is 26 spline axles. carrier 3 came out with 3.23 or lower which have 28 spline axles. ur car has carrier 3. u need to find out wat gear his car came out with factory if its was a 3.23 it will work. but if it came out with 3.08 or 2.73 it want work the ring gear will be a different thickness i done the samething i had to learn the hard way
