why would he do that?
Old Apr 18, 2007 | 10:08 AM
kfred21's Avatar
Default why would he do that?
i bought my '94 z-28 about two months ago and have been doing a little work on it here and there. right now it is running rich and is not running like it should. i replaced vacuum lines yesterday and came to find out that the guy before me removed the optispark. i know for a fact the it has a bigger cam and he also deleted the egr/air. does any of that have to do with why he removed the optispark?
Old Apr 18, 2007 | 10:29 AM
LiENUS's Avatar
If he removed the optispark what is the car using for spark distribution?
Old Apr 18, 2007 | 10:39 AM
Hot94Z28's Avatar
Does it have a Delteq system?
Old Apr 18, 2007 | 10:55 AM
kfred21's Avatar
honestly i dont know. i have already come to the conclusion that the guy i bought it from is an idiot. i'll have to take another look to see what i can find.
Old Apr 18, 2007 | 10:58 AM
04gtoBMXracer's Avatar
how is it running?
Old Apr 18, 2007 | 11:00 AM
LiENUS's Avatar
The stock pcm won't run without the opti, the opti HAS to be there in one form or another. The only situation where someone has successfully removed the opti from the front position behind the waterpump and ran the stock pcm was where he hacked up the opti and fit it the standard sbc location and then ran the delteq system with that. Even if the guy did that (highly unlikely) the opti is still there its just on the back of the intake manifold. But chances are the opti is still there, if hes running the delteq or ltcc systems youl'l either have 4 or 8 coils instead of the single coil that comes stock.
Old Apr 18, 2007 | 12:08 PM
kfred21's Avatar
my car is running rich. when its cold and i start it up it dies, unless i give it some gas
Old Apr 18, 2007 | 12:34 PM
LiENUS's Avatar
running rich? How do you know this? Whats rich? Did you know that in cold start up mode with the stock computer your car can run as rich as 7.6 to 1 air fuel ratio and still not be too rich for cold start? Assuming the temperature is between 60 and 80 degrees your cars computer will command an air fuel ratio anywhere from 10.4 to 1 to 14 to 1 air fuel ratio. even 14:1 is richer than the stoichiometric ratio of 14.7:1. So whats rich in a cold start? Far more likely the cold start problem is caused by your idle air control motor than the car running rich. Heck it could be as simple as a clogged up idle air passage, spray some throttle body cleaner in there before you go assuming the optispark has been removed. Because I can guarantee you, unless its running an aftermarket computer like F.A.S.T. or MegaSquirt. Your optispark is still there in some for or another. And almost all of the methods of "getting rid of the optispark" still require the optical portion of the optispark (and hence at least 77.7% of the function of the optispark) to still be there right behind the water pump and if the guy did use a system such as delteq to run coil packs instead, you should be thankfull.
Old Apr 18, 2007 | 12:48 PM
LT1Falcon's Avatar
can you give a better description of "removing the opti"? you mean none of it is there?
LT1Falcon's Avatar
also, where are the spark plug wires going to?
Old Apr 18, 2007 | 02:58 PM
krayzie7th's Avatar
how you getting your car started if it dont have and opti?
Old Apr 18, 2007 | 03:15 PM
kfred21's Avatar
i just took the air intake off and took a closer look and the optispark is there. but i still do not know why my car runs the way it does i'm gonna have to get it tuned i guess. only problem is i dont know what size cam is in it
Old Apr 18, 2007 | 03:19 PM
LT1Falcon's Avatar
what made you think he eliminated it?
Old Apr 18, 2007 | 03:45 PM
LiENUS's Avatar
As I said check the idle air control motor, make sure its working and that its passages aren't clogged up. btw large cams make cars run rich at idle. Thats a fact.
Old Apr 18, 2007 | 05:08 PM
ckyconan2003's Avatar
Do these things before going any further
1. Find out what cam was put in there and know the specs
2. Find out if the car had been rebuilt or bored out to a 355+
Get the car tuned, or else it will run rich.
Old Apr 18, 2007 | 05:25 PM
kfred21's Avatar
i thought it was eliminated because with the vacuum line kit i got, one of the lines is suppose to go from the intake to the optispark vent but i did not see any of the factory lines going to the optispark from the intake. so that was my dumb *** stupidity
Old Apr 18, 2007 | 05:39 PM
Ralls's Avatar
That's because it's not a vented optispark. It doesn't use the vacuum line. That's the later years.
Old Apr 18, 2007 | 08:56 PM
Formula350's Avatar
lol This thread is such a jumble. Is the ECM tuned? Do you have new O2 sensors in it?
