Cam Advice
Old 04-19-2007, 12:46 PM
bursty's Avatar
Default Cam Advice
I know I know, its been beaten to death, but the search isnt working.
I'm swapping an 02 LS1 from a Camaro into the RX7 (see sig). The engine is out now and figure now is the best time to do a cam swap. The car will have long tubes, no cats back into a Magnaflow muffler, custom CAI, and stock heads for now.
I ordered a T-Rex cam package from TR last week during their 10% off sale. I'm now having second thoughts about running it on the stock heads. The RX7 will only weigh 2600 lbs or so, so I dont necessarily mind losing some lowend torque. Also, driveability isnt that much of a concern because this isnt a DD. The RX7 also comes with 4.10s stock in the rear.
My questions.....should I stick with the T-Rex? What power should I be at on the stock heads? What about after adding some ported LS6 heads? I assume the stock heads will be the main restriction on my setup after adding the T-Rex.
Also, I've never tuned a car, but was thinking about ordering HPT and trying it myself. I assume there are some T-Rex tunes in the depository that I could use as a template?
Any other cam recommendations?
Thanks guys
Old 04-19-2007, 01:18 PM
lilbuddy1587's Avatar
Thanks guys
Seeing as how light the FD is and that it comes with 4.10's as is, I'd stick with it because you aren't going to need X amount of low end torque to get moving. That sucker is light! Make sure you clay and check PtV though, thats always a good safety net. The T-rex is designed to work with stock heads, so there shouldn't be a problem and of course you can expect a nice increase with the addition of heads.
Bottom line, I say go for it man
Beautiful car btw!
Old 04-19-2007, 02:42 PM
black01_WS6's Avatar
keep the cam and run it for the exact same reasons as posted above. That cam is a great choice for that car if staying with stock heads.
Old 04-19-2007, 07:29 PM
bursty's Avatar
Will the stock heads be a huge restriction? How much gain will I see if I go to ported LS6 heads?
Old 04-19-2007, 08:37 PM
No, the cam was designed for STOCK HEADS. Ported ls6 heads would give an average of 25-30whp and more through out the curve.
Old 04-19-2007, 08:47 PM
bursty's Avatar
Awesome, sounds good. What about tuning? Think I'd be able to make it work using HPT and a T-Rex tune from the repository?
Old 04-23-2007, 07:16 PM
bursty's Avatar
TTT, any advice on tuning?
Old 04-23-2007, 08:02 PM
someone will have a bin file that I am sure you could use. I would still throw it on the dyno after, just to make sure everything is dead on.
