boost on a 3 bar fast unit ?
Old 04-22-2007, 01:34 AM
otherwhitemeat's Avatar
Default boost on a 3 bar fast unit ?
what happens when boost goes past the limits of a 3 bar map sensor on a f.a.s.t . aftermarket comp.? its the old style box......will it still work?
i need to run more then 30psi and the fast computer and map sensor are good to only 30.........i think.........please help!!!!!!
Old 04-22-2007, 01:39 AM
coop5885's Avatar
the sensor will be maxed out and the computer wont know how much boost its getting. Its kind of like having a MAF car with the MAF maxed out. You can trick it into fueling with the VE, but it can be a gamble.
p.s. a three bar sensor is good up to 28lbs
Old 04-22-2007, 01:42 AM
98turbls1's Avatar
Holy crap if this is in a LSX combo... Good luck man
Old 04-22-2007, 07:34 AM
[QUOTE=coop5885]the sensor will be maxed out and the computer wont know how much boost its getting. Its kind of like having a MAF car with the MAF maxed out. You can trick it into fueling with the VE, but it can be a risk
so i can keep it fat at the end of the table and the computer will go with the last VE settings? and as long as the car doesn't lean out under a few more psi it "should" be ok?
Old 04-22-2007, 12:26 PM
RealQuick's Avatar
Thats alot of boost for an LTX (even forged).
Old 04-22-2007, 12:32 PM
Sawzall and Welder Mod
Whistler's Avatar
Yes, it will stay on the last table it saw before going out of parameter.
Old 04-22-2007, 12:38 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Hehe sounds sick Jesse. Before we fixed my valvetrain issue my car saw 26psi a few times. :0
Old 04-22-2007, 01:15 PM
With the pt88 i ran it as hard as i could and it would hit 23-25 psi and was done after that. But with the t91 I will be surpassing that, and i forgot about the limits of the older f.a.s.t. units and I really don't want to buy a new system this year.
Old 04-22-2007, 01:27 PM
Z8'S's Avatar
Get the updated firmware and it will be good to 5 bar. A number of companies make a 5 bar sensor.My 1.02 version has it .My unit is 10 years old.
Old 04-22-2007, 04:18 PM
can i get the updates through f.a.s.t.?
Old 04-22-2007, 04:35 PM
Z8'S's Avatar
Yes Get ahold of Craig Smith at Turbo buick .com he'll hook ya up.
Old 04-22-2007, 07:42 PM
Ok ...thanks for the info I appreciate it.
Old 04-22-2007, 07:50 PM
Whistler's Avatar
They have a 3.5 bar sensor too. Probably more use for those that a 3 bar is barely not enough for, without losing too much resolution.
Quick Reply: boost on a 3 bar fast unit ?
