Melling High Volume Oil pump w/Rollmaster Double Roller
I did a search and found a few threads but none seemed difinitive with regards to being able to use a Double Roller with the Melling 10296. I saw some saying they need to clearance the front cover and others stating they had to clearance a coulple spots on back of the pump. I am looking for somebody who has a Melling High V Pump and uses it with a Rollmaster Double Roller...what needs to be done to run this combo?
Thanks
Thanks
Originally Posted by ls1290
I have the Melling oil pump and a rollmaster timing chain on my 402 LQ4 combo. No clearance problems and I am using the timing cover from my old LS1 block.
Keith
Keith
Do you have the high volume version #10296?
Are you using a Double Roller or Single Rollmaster?
Thanks
Dumb Ass Vette Moderator
Thanks
Thanks
Keith
I have one of these pumps I just installed w/ a rollmaster double roller. Is the clearance issue obvious when you put the cover on or is this something that you dont notice until the car is started with a rubbing or grinding of some kind?? My cover went on fine, no binding or anything, just want to make sure.Thanks.
Mine went on just like that also. From the sounds of it, if there is clearance issues with the cover, they are completely obvious.
Keith
Keith
I just got the pump and measured it against my LS6 Katech ported pump, there is approximately 1/16" difference between the two...the Melling being the thickest out of the two.
So if my front cover doesn't fit with the Melling pump, it appears that the most I will have to grind is about 1/16" of an inch where the bolts on the pump meet the front cover.
I am thinking since I am feeding an oil cooler and two turbos..that I will leave the Red spring in it....the way it came.
Keith
Also keep in mind with the double roller, there are shims. The shims will move the pump out and closer to the cover their width, so you might have to grind the 1/16" + the width of the shim.
Keith
Keith
Yes you are correct and thanks for looking out. I actually have had the double roller for sometime and had to use the shims with my LS6 pump....so I understand exactly what you are referring too...but appreciate you mentioning it.....I should have titled my post a little different as it makes it sound like I am adding both parts at the same time...the reality is I'm just adding the Melling Oil pump to my setup that was already using a Double Roller.
