Advanced Engineering Tech For the more hardcore LS1TECH residents
GMPP vs Victor Jr. Carb Style.... runner length and peak HP question?
Old 04-22-2007, 11:41 AM
WizeAss's Avatar
Question GMPP vs Victor Jr. Carb Style.... runner length and peak HP question?
I have a GMPP L92 intake.
My question is:
On a traditional LSX cathedral setup, you have the choice of a edelbrock and gmpp intake. The GMPP is shorter, and has shorter runners. The Edelbrock piece sits higher and has longer runners. I took my L92 GMPP intake and sat it next to a Victor Jr. It is much shorter but has much larger volume runners.
Which one will peak RPM the highest and why?
Also will hogging out the GMPP intake raise or lower the rpm? What can you do to add more low end torque? Do spacers make a difference??
Old 04-22-2007, 11:47 AM
WizeAss's Avatar
Originally Posted by danf1000
runner length and runner diameter. with a set length (such as a pre-exisitng design) the only variable is diameter, or sectional area. if possible this area is kept as consistent as possible.
longer and smaller cross section runners are good for torque and short fat runners are better for high-end horsepower, generally speaking. but you already said that.
found this in another thread.
I assume the GMPP intake peaks much higher then the victor jr...... but what happens after you port it? Should I just smooth it out and leave it unported due to losing low end torque?
Old 04-25-2007, 07:28 PM
LSxChevelle's Avatar
Also interested...
Old 04-25-2007, 08:48 PM
edgz06's Avatar
You need to give more details on your engine combo.
Forced induction or naturally aspirated?
Cam specs.?
Gears?
Obviously your using L92 heads, but any port work on the exhaust side?
Old 05-04-2007, 03:32 PM
8ty8 LS1's Avatar
wouldn't a longer runner create more friction loss?
Old 05-04-2007, 03:44 PM
BryanJohnson's Avatar
i believe the victor jr is maxed out at an earlier rpm than the gmmp intake and will more than likely make more on the low end. the gmmp re worked likes big rpms, thats where it likes to be. i am just speaking for myself with my na LS based solid roller build. it hasnt been dynoed yet, but time will soon tell.
Old 05-04-2007, 03:59 PM
HataErasa's Avatar
interested as well
Old 06-03-2007, 02:49 PM
WizeAss's Avatar
so... compare what happens when you swap the wider ports on a GMPP intake for longer runners on the victor jr? Would it be wise to "port" the GMPP intake or would you just polish it up?
Old 06-04-2007, 06:05 AM
WOTFMAN's Avatar
Im interested in this myself. Id like to think it would be wise to port the Gm and at least give it more plenum volume.
Old 06-10-2007, 11:15 AM
LSPerformance's Avatar
If getting from A to B quick is your game, I've found this to work and be within 100 rpm every time
97000 / runner length from valve seat to plenum = hp peak rpm
hp rpm peak x .85 = torque peak rpm
Old 06-13-2007, 09:42 PM
Restricted User
98Z28CobraKiller's Avatar
Are we using inches for the runner length?
Old 06-14-2007, 10:43 AM
Yes, use inches.
Quick Reply: GMPP vs Victor Jr. Carb Style.... runner length and peak HP question?
