ETP ls7 heads worth it?
I too am considering putting LS7 heads on a N/A 427. I have seen ETPs mentioned on this forum but must admit to not knowing anything about them. Are they reworked Chevy parts or are the ETPs own castings? What is the cost? Are they complete or bare? I have seen Chevrolet's LS7 go for 1250 each complete. I have been to the ETP web site and seen the flow numbers that are very impressive. HELP PLEASE?
Well to give you an idea, my ETP heads (should be ordered up next month!) are gonna cost me around $4,000. But that's with upgraded exhaust valve, valve seals, and springs. Base is around $3200 for a set of LS7 heads.
I'm more looking for increased flow over GM ls7 heads....pros and cons and what applications which heads would be best for. I'm running mostly na with only a juice shot once in a while.
Collections Hold
etp ls7
Our LS7 heads are made from our own castings, they are not reworked GM heads. We originally made our heads for use in hot applications that would require larger springs and the thick deck. We also use a stainless vavle combo to get away from some of the problems associated with titanium vavles on the street. They are user friendly when teamed up with either Jesel rockers or stock LS7 rockers. No machining ness. They also offer more material if they are ported further in the future. The exhaust port is quite a bit better than the stock port. The intake port is slightly larger (6 cc) than the stock LS7. I have had feedback from customers that they did perform better than the factory heads, some were as high as 30 hp, some lower. I do not push them as an upgrade to a stock LS7, but as a better base cylinder head to start with that has room to improve or to run with solid rollers. The base price is 3199.
Originally Posted by Six Speeds Inc.
What is the lead time on a set of the ls7 heads. Might need some for the next project.
From what I can gather, the ETP's are the way to go with high output, high compression and/or FI applications due to their thicker deck. I don't really want to drop the extra coin on ETP's vs. L92's either, but I am going FI and want to use an LS7 intake because it flows much better than the L92. I think the l92 heads are out flowing the intake, so you really need to run a sheetmetal intake to take full advantage of the heads. There still are no aftermarket rockers for the l92's and valve material is limited.
John,
Check out some of the results from Speed INC and their twin kits. Most of them are done with a factory LS6 intake. Unless you are going for 1000 + at the wheels, you should be fine with a factory intake. and heads. Many of their results are done with Patriot heads.
Collections Hold
ti valves
I have not seen any issues with our heads with the Xcelldyne valves onthe street. We have them hard coated though. I have heard of issues on the factory LS7 valves, but I will not speculate because it may be an isolated problem. I dont like the powdered metal valve seats with Ti, we use a softer ductile iron seat as per recommended by the manufacturer.
Originally Posted by Stang's Bane
From what I can understan about the Factory TI valves Cary, it is not a isolated issue. Basically, if one puts a very aggressive cam under them. The tips wear down until the lashcaps fall off........... or they just break.
And too bad nobody seems to make a roller rocker for the LS7 head yet.
Originally Posted by 71CamaroLS1
I wonder how much these issues are related to the stock LS7 rockers - the wipe pattern may be such that the rocker tip is creating a bad loading condition at higher than stock lifts. Also, if big dual springs are used with a big cam, rocker tip loads will go up dramatically as a result of the greater spring/retainer mass. That's why I'm definitely going with the Katech behive springs/retainers on my build ...
The only roller tip rockers are Jesels $$$$$$$. I have a couple leads on some people that make them custom for a little less, but it would be nice if there was a mid level option
Collections Hold
vvv
We like to use copper alloy seats with the Ti valves, Our standard ductile iron seats are 32-35 Rc hardness which is still compatible with Ti valves. any fliud trapped between the valve and the seat when the valve closes is very hard on a titanium valve. Stainless is much more resistant to hydraulicing at the valve seat.
I know about the valve tip issues on the stock LS7 valves, but since I don't have a real answer on the actual failures, I don't like to make my own assumptions. there is a lot of hypothisis' out there for failures. They are not always what we may think.
As far as rocker arms for the LS7, Yella Terra makes a real nice light weight setup for our heads. WE don't have integeral rocker bosses, so they are much easier to adapt to aftermarket rockers.
