Look at this input drum. Is this ok?
Old 04-22-2007, 09:08 PM
Kiss_My_99SS's Avatar
Default Look at this input drum. Is this ok?
Are these cracks normal? Why are the 2 holes bigger on one and not the other?
drum1
drum2
drum3
drum4
Old 04-22-2007, 09:35 PM
FLT
FLT's Avatar
The holes are different sizes because I believe this is how the balance the drums. As far as the cracks, your pictures are kind of unclear. Sorry They might be just marks from when the drum was casted.
Old 04-22-2007, 10:13 PM
I can feels some of the cracks with my finger nail. How can i tell if they are just casting flaws? My old drum does not have any marks like this. Is it common to see marks like these?
Old 04-22-2007, 10:22 PM
FLT
FLT's Avatar
I have seen it in the past. Casting marks at times do look like cracks. I usually will look on the inside of the drum and see if it is a clean break. If you have doubts do not use it. By the way your links do not work.
Old 04-22-2007, 10:24 PM
I just fixed the links you should be able to tell more now.
Thanks for your help.
Old 04-22-2007, 10:26 PM
The inside of the drum looks fine no marks.
Old 04-22-2007, 10:53 PM
2002_Z28_Six_Speed's Avatar
I would say that it is not a crack. Looking at pics 3+4 I noticed that the mark in question didn't go into the recessed, machined area and if it was a crack it should be visable there. The depth of the surface imperfection is minute.
Looks like surface imperfection from die casting.
Pic 2 doesn't look like this though sigh
Old 04-22-2007, 10:55 PM
FLT
FLT's Avatar
The links work for me now. It does look like a casting mark to me.
Old 04-23-2007, 12:05 AM
LS1Tech Sponsor
performabuilt's Avatar
agreed from looking at links they are just casting marks
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-23-2007, 01:13 AM
smoknta's Avatar
Sand it down slightly and see if they go away. If it is a casting mark, it should sand right away. If it does not go away it is a crack.
Old 04-23-2007, 05:32 PM
PBA
PBA's Avatar
Yes, they look like casting marks, have seen this a few times.
