question on t-tops
question on t-tops
quick question about t-tops. I shattered one on the free way not to long ago i have a 2001 ws6 are all the 93-02 t-tops the same? camaro and bird?
Not sure if they are physically different in size or whatever, but I do know they look different. Mine has a black layer with small holes cut out on the underside; sort of like the honeycomb taillights. I don't know how to explain it without pictures. Ls1's are clear right?
whats the major difference i buddy of mine at work says his gf is gana part out a 96 camaro with t-tops and if i can get em cheap and they fit i'll jump on them.
I don't have any pictures and it's too dark right now to get one. Your t-tops are clear glass right? Or maybe a little tinted. Lt1's have a pattern that looks a lot different than yours.
One thing though.. do you have the covers that fill in the t-tops and completely block out light? I know camaro's do. If your going to cover them up anyways, I would get those `96 t-tops.
i do have the shades but they have never been attached to the car i like looking out the tops while i'm cruising. if it has the dot matrix thing i might have to reconsider. i do usually have the tops off any way but i would like to have a set in case it rains
Originally Posted by PipesTA
^^^ Exactly. Newer ones are going to be tinted and the older ones have a dot matrix like on the upper part of your hatch glass.
Yep, I had to use a t top off a 93-94 with the dot matrix when mine pulled a James Bond on the road. In all honesty, it didnt look like it fit right and it leaked like a bitch. I picked one up from a guy on here off a 99 I beleive and the leak ended. I put my buddys on from his 95 and it fit just fine too. As long as you get one 95+ it will look the same visually and shouldnt give you any problems...hopefully.
yeah there all the same
