Sponsored by: DashLynx
Plastic Headlight housings?
Old 04-24-2007, 10:52 PM
DirtyBird222's Avatar
Default Plastic Headlight housings?
Where to find them for 2000 T/A? If anyone has any laying around let me know please I'll take them off your hands!
Old 04-25-2007, 03:35 AM
transambandit's Avatar
try the junk yard
Old 04-25-2007, 10:10 AM
no junkyards around my area have 98+ firebirds
Old 04-25-2007, 10:26 AM
LILWS6's Avatar
what do you mean by plastic arn't they all glass?
Old 04-25-2007, 10:31 AM
Andros's Avatar
I think he means the plastic cover that goes over the actual headlights.
Old 04-25-2007, 10:35 AM
Nope I'm talking about the sealed beam low beam headlight housing that came on most of the cars from the factory. Most aftermarket headlights are glass. But few were plastic.
Old 04-25-2007, 10:42 AM
see these are plastic headlight housings from an LT1
Old 04-25-2007, 05:12 PM
bump bump bump
Old 04-25-2007, 09:39 PM
LILWS6's Avatar
well if you find some let me know as well i want to put aftermarket bulbs in mine but i have glass sealed beams
Old 04-25-2007, 09:52 PM
Danny2tek's Avatar
To my knowledge they are all glass (ls1's). When they burn out you replace the entire capsule. Unless you go with the empty capsules they sell to use with H4/7 bulbs (like mine)
Old 04-26-2007, 04:11 PM
steady01's Avatar
******* hot
steady01's Avatar
bummp!
Old 04-26-2007, 05:21 PM
SCRWS6
Guest
Posts: n/a
All the aftermarket sealed housings I`ve bought have been metal in back and glass in front, makes it easier to upgrade bulbs if thats what your wanting to do.
Old 04-26-2007, 06:14 PM
LILWS6's Avatar
where you find those at thats what i'm looking for?
Old 04-26-2007, 09:51 PM
The ones with the projectors in them? That was a project I was working on for my LT1 car.
No I don't want glass housings, I need plastics ones so I can basically do the same thing. But looks like I'm gonna have to go completely custom because once again GM uses dated technology
Old 04-26-2007, 10:46 PM
Copy & Paste Moderator
VIP1's Avatar
What are you trying to do?
I recently installed Hella H9 Projectors in my 2001 Formula. I read through some threads over on Full Throttle V6 and gave it a shot.
http://www.fullthrottlev6.com/forums...ad.php?t=22874
http://www.fullthrottlev6.com/forums...ad.php?t=23020
http://www.fullthrottlev6.com/forums...ad.php?t=23217
http://www.fullthrottlev6.com/forums...ad.php?t=23289
http://www.fullthrottlev6.com/forums...ad.php?t=23782
I found those threads searching Google at 1AM about a week ago (I was still searching for info at 2AM... Donaimian can tell you how much sense I wasn't making at that time in the morning).
Old 04-27-2007, 09:46 AM
SCRWS6
Guest
Posts: n/a
you can get the housings with bulbs at autozone, just stocker replacements that you can remove the bulbs and use what you want, otherwise some good links above..... I only used these for high beams though, bought some projectors off ebay for the low beam
Old 04-27-2007, 12:48 PM
VIP1's Avatar
Huh? Where?
I've never seen them.
Thats news to me.
Any pics, prices?
Unless you are talking about making a conversion housing using stock replacements. I did that for a while, but I didn't like it.
Old 04-27-2007, 01:20 PM
SCRWS6
Guest
Posts: n/a
exactly... its hella easier than trying to remove the bulbs from the all glass ones....spent quite a bit experimenting with em, you know how projectors are deeper than our lights? turn em around inside the bracket that holds the headlight on. gives you more room inside and the headlight still opens and closes just fine....I go crazy tryng to get some of this stuff to work ....
Old 04-27-2007, 01:30 PM
VIP1's Avatar
I'm not following.
What are you talking about? pics?
