Any experience with bored out high Imp injectors for FI? Link inside.
Coal Mining Director
http://www.schimmelperformance.com/O...jector90lb.htm
Trading email with the owner since Stevieturbo posted this in the Vetteforum. Schimmel claims 1.2ms down low. Designed for turbo VW's and Porshe's. Basically a bored out Delphi Bosch Injector.
I wonder how consistent they are.
A 90lb/min high imp injector would be killer.
Thoughts?
Thoughts?
Originally Posted by INTMD8
Are you running out of injector?
Some joker sold me a turbo kit that has my Mototron 60's at +80% duty at 6400rpm at 12psi of boost at a steady 84psi fuel pressure.....
Not out....but it's waving adios.......
I'll take them to 100% and see where the boost tops out.
Originally Posted by JZ 97 SS 1500
Box and 83's, or 96's depending on power. Don't bother with high Z injectors above 60.
http://www.lingenfelter.com/images/C6ZO6EL03.jpg
How do you control the second set of injectors shown here?
Originally Posted by PHIL H
I was wondering about that..I see Venom makes a high imp 96lb injectors and was wondering..Anyone ever try them?
Do a google search on Venom....lots of QC problems from the mustang and supra guys posted everywhere.
If you can still command an AF ratio of 11:1 and it holds across your rpm range then they should still be ok...
As I said. A friend in Malta has used the 90lb Schimmel injectors on a couple of 4 cylinder turbo cars with great results. He reccomended them to me after he threw some money away on some Venom pieces of ****.
Ive also used some modified side feed high impedance 1000cc injectors on a 2.35 litre Subaru, and they performed superbly.
Not all injectors are the same, although in an ideal world, yes, Low Z's would be preferred at that sort of level.
