Forced Induction - how much boost for LT1???
procamaroz28
04-26-2007, 05:20 PM
i have my mind set on getting a blower on my 94 z28 but will my stock block be able to still remain my daily driver with an extra 7+ lbs of boost
what is my boosting limit??
im gonna build a 4 bolt main short block from a vette how much more will that handle???
otherwhitemeat
04-26-2007, 05:22 PM
do you mean stock internals too?
procamaroz28
04-26-2007, 05:24 PM
yea all stock exept for my next sb
koolaid_kid
04-26-2007, 05:28 PM
While the boost level will be limited due to the compression ratio, your bigger limitation will be the bottom end. If you have a stock bottom end, you will be limited by its strength. Go too high and you may be building that other engine sooner than you think. So your question should be phrased more like "How many rwhp can I run safely on the stock internals?".
Ari G
04-26-2007, 06:20 PM
LT1 with the pink pistons and rods can handle 500-600fwhp if everything is right but not forever
engineermike
04-26-2007, 07:00 PM
This question is asked weekly on camaroz28.com.
procamaroz28
04-26-2007, 08:04 PM
thanks
koolaid_kid
04-26-2007, 09:16 PM
LT1 with the pink pistons and rods can handle 500-600 fwhp if everything is right but not foreverHmmmm.
Take a look at our '95 formula. The internally stock engine has been on 9 psi of boost for four + years.
http://www.exoticperformanceplus.com/projectCar.php?car=7
Video http://video.ls1tech.com/video/89b2f58a-ae2c-42e5-b799-98a4011bec07.htm Bob
koolaid_kid
04-27-2007, 05:19 AM
Thanks, Bob. Is it still running 368 rwhp.?
How many miles does it have on it now?
I spoke to someone last year who said he was running 450 rwhp on his LT1 (mods plus Procharger), but it grenaded on him after about 25k miles.
Yes, it is still at about 367-368 rwhp. The 4000 stall give it lower rwhp numbers than what it really is producing. This car only has 5000 miles it, a lot of them are 1/4 mile at a time. Bob
procamaroz28
05-01-2007, 08:14 PM
thanks again but before getting the blower i think ill build that 4 bolt beefed up lt1
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
