need help plzz
need help plzz
hey guys im new so take it easy lol anyway i have a dvd in dash and a jl w6 v2 with a phionex amp 1000w and to new duel front speakers from wal mart. i just got all this in my 1997 firebird with the Monsoon system when i turn it up to a certian point the speakers shut off and the amp still playing if i turn the head unit off and back on ll is fine only does it when i tun the hu up past 20 did with my old pioneer also the head unit is fine had it replaced so any help would be nice my firend thinks the Monsoon amp is doing it but how do u fix this if this is so
Ok I have a 1997 firebird 3.8, I have a Jensen In-Dash DVD/CD Receiver with 7" LCD Monitor (VM9312), a JL w6 v2 sub with a phoenix amp 1000w has the stock monsoon system in there I replaced the 2 front speakers with these duels 4 ohm from wal-mart the 2 speakers in the sail panels r not hooked up and the driver side 4 in the rear is not hooked up but when i turn the music up past 20 on some music and 25 on really high pitch stuff the highs and mids go off and the tweeters and sub keep playing if i turn the HU off and back on is fine till i get passed 20 my old HU did the same thing and i had Circuit City replace my new HU so any help will be nice
Originally Posted by deadman29852
like i said all stock system just took out the 2 front and replaced and took out the subs they were blown umm u got to let me know what u mean a diagram
You have the Monsoon system hooked up, added the pheonix amp to run the subs (JL). You replaced the front 2 speakers with ones from Wal-Mart.
When you hooked up the front speakers, did you hook them up to the right set of wires? There are 4 there, 2 for the mid woofer and 2 for the tweeter.
Also to me sounds like you might have a short like stated above.
How do you know the headunit goes to 25, do you have an aftermarket one or still the Monsoon?
i have the Jensen In-Dash DVD/CD Receiver with 7" LCD Monitor (VM9312) theres only 2 wire in the front speakers thats what i hooked up
so you hooked the speaker output on the radio to the front speakers, and the front speakers are still hooked up to the Monsoon amp?
A diagram is a simple drawing of how your system is layed out.
ok....
You are running the tweeters off the HU and everything else off the Monsoon amp.
Sounds to me you might be over powering the Monsoon amp inputs and it is shutting down, going into protection mode.
Thats what my friend said it might be doing but how do i stop that shoud i get all new OEM speakers
