need some serious help...
think of the front of the engine torn down, viewing the bare crank snout, and just the retaining plate and cam in place. oil pans been dropped about 1/2 inch so i could take off the pump and the oil pickup tube is open. got that visual?....
now visualize the far left retaining plate bolt falling into the oil pickup tube....got that?
thats what happened...need idea's to get it out!
i tried to drop the pan to see more of what i had to work with...i need some input on what i can do to get this thing out!
only idea i have is get a magnet and slide it inside the tube and try to fish it out the hole.
thats really all i got aside from pulling the trans, dropping the pan and getting it out....brain storm fella's...any idea's?
thanks for any help..
Jon
Jon
Jesus man, thats just bad luck! Im pretty sure the pick-up tube has a screen at the end, so hopfully the bolt didnt fall into the pan. The best thing I can think of doing is what you already said. Try bending the pen magnent to get it as far into the pick-up tube as you can. Hopefully it will catch for you! Keep us posted man.
i looked around on google and couldnt find any good pics. Try taking a metal hanger and sliding it down there to see if you can feel the bolt. If so try bending the hanger accordingly, and try and match a pen magnent to how the hanger looks. Just dont push down with the hanger to hard, or you might knock that screen off the end, i dont know how well its attached.
Jon
ill keep fishing and see what i come up with...I'm tring to think of what else i can use besides the hanger thats flexable/strong but cant think of anything. I'm thinking about a vacuum and tring to suck it out...wonder if that would work..
i think there is only one bend. it curves towards the middle of the pan i believe. And it probably ends in the deepest part of the pan.
well i dont think it angles straight down. If you run your finger along the front(as far as it will go anyway) you can feel the tube slanting down. So i think its just the one bend, with a gradual slant to the deep part of the pan.
You could even duck tape a small magnent to the end of some 12-10 gauge wire, and just fish it down in there. Just make sure the magnent is secure, you dont want something else falling in there.
If you can run along the outside of the tube, a strong enuff magnet should attract through the tube, then run the bolt to the top opening. The bolt won't make it to the pan due to the pickup screen.
i got the pan down lower and i can see it has 4 bends. i can get it past 2 but cant the 3rd with the hanger. ill have to find something more flexible but yet still strong enough to keep the magnet from sticking to the tube...I'm gonna try the vacuum tomorrow..
Jon
Go under, release the subframe bolts, jack your motor a couple of inches, remove oil pan, remove tube and get that bolt out.
While you're in there, swap the rod bolts with Katech's and there you are a misshap turns into a nice deed.
There is a sticky atop this forum to show you the steps.
Jon
