cam
cam
Does anyone have the facilities and tools to put my cam in, or at least help me. I have no Idea what Im doing. I am also in arlington, and its my only form of transportation, so It will have to be done quick. I am off work on friday and saturday, so any help would be great.
chris
chris
Originally Posted by KrautBurner
you will probably need some valve springs and new pushrods too (that's over $300)
good luck
good luck
Originally Posted by vetred
AND,......timing chain,.......hardend push rods,....80mm throttle body,..(BBK., $319 !) BIGINTAKEBIGMANNIFOLDBIGHEDDERSBIGHYFLOWCATSBIGAXC ELBACK,.........AAAAAAAAAAAAAAND A partiridge in a pear tree!!!!! (actualy im NOT kidding one bit),..(except for the partridge thing) (sorry)
I know he is selling the cam now due to selling the car but it's just a hotcam so why the 'need for pushrods. Yea if you go driving the car to it's limit all the time ok...but for a driver that gets on it once and a while I'd even consider leaving the stock springs.
Tech Addict
Springs, pushrods and an oil pump are a no brainer if you're doing a cam swap. Timing set too if you're gonna have it apart for a cam swap. I don't think I'd want to test the stock springs on a hotcam or any aftermarket cam for that matter.
Thanks for the info, but the cam is for sale now, and my car is gone anyway. Thanks guys.
Specifications
SDPC Part Number: 12480033
Manufacturer: GM Performance Parts
Advertised Duration Int. : 279°
Advertised Duration Exh. : 287°
Camshaft Duration @ 0.050" I/E : 219°/228°
Camshaft Lift I/E : 0.525"/0.525"
Lobe Seperation Angle : 112°
RPM Range : 2200 - 6500
Camshaft Type : Hydraulic Roller
Specifications
