ABS Que stion...
Originally Posted by TheBiz
Looking to by the SJM ABS delete kit. How do I know if I have a 4 channel or a 3 channel ABS.
Look to see how many brake lines go to the rear of the car from the ABS unit under the hood. there should be 2 going to each side of the front, then one to the rear, or two to the rear, just depends on the vehicle..
LOL I asked this like a month ago if you have Trac control you have 4-channel if not then you have 3-channel. Also if you want if you have TC and delete the ABS you can delete the TC also.
