Trans Stuck on Engine!!
Old 05-05-2007, 10:47 AM
99Z28vert's Avatar
Default Trans Stuck on Engine!!
My trans is stuck on the damn alignment pins. Got 8 bellhousing bolts out, converter is unbolted and spins freely, got the crossmember off and I've literally been kicking this thing back and forth and beating it with a big *** hammer. I can't get any gap at all to even pry on. It's soaking in PB blaster now, but anybody got any tricks or ideas on getting this apart? This is ridiculous.
Old 05-05-2007, 10:58 AM
SSPerformance's Avatar
get some PB blaster spray the dowel pins from the back as good as u can and take a mice big pry bar and work the trans a lil it will come out just takes some time. Ive had a few stubber ones like this
98turbls1's Avatar
Try to get a really thin pry bar of some sort and get a hammer to lodge it in between the engine and bell housing...That's what I had to do to my T56 because that thing was almost welded on...Keep trying
Old 05-05-2007, 11:11 AM
99Z28vert's Avatar
Problem is the only place I can get so much as a screwdriver in is between the trans and oil pan, doesn't seem like a good place to pry.
Old 05-05-2007, 11:19 AM
LS1Tech Sponsor
performabuilt's Avatar
Keep working with it and the PB blaster . I have heated the dow pins but dont suggest it unless you clean off the PB blaster and have a oil free area and a good fire ext. But be carefull with the pry bars the bellhousing isnt that tough and will break. I have see a few .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-05-2007, 11:44 AM
fastlane02's Avatar
just keep working at it with some pb blaster and pry bar. took me 2 hours to get mine apart. pissed me off
Old 05-06-2007, 02:56 PM
99Z28vert's Avatar
Heat and a big *** screwdriver did the trick. Thanks guys.
Old 05-07-2007, 09:51 AM
VORTECFCAR's Avatar
If you have a come-along or ratchet strap try hooking one end on the tail shaft housing and one on the rear end. Then work the strap while using the other methods. This was the only way I could get mine off. I broke a couple large flat blades trying to pry and PB blaster didn't do ****.
My dowel pins eventually pulled out of the engine.
Old 05-07-2007, 11:30 PM
SunsetOrangeZ's Avatar
Are you trying to pull it off with the full weight of the tranny pulling down on the pins or do you have a jack under it and have it tucked back up. Mine cracked loose once I took some tension off it.
Old 05-08-2007, 09:42 AM
transam69230's Avatar
VORTECHFCAR i didn't know you had to use a ratchtching strap thats funny, you didn't tell me that
Old 05-08-2007, 08:28 PM
NOS4EVER's Avatar
I feel ya
Keep 2 bolts lose then have some one with a strong leg push the tale section with a another person with a long peace of wood and a hammer hitting it from the same direction.
If you pull it down you may hurt the back of the intake and the sensors.
Good luck
Old 05-10-2007, 01:12 PM
VORTECFCAR's Avatar
glad you got a laugh, I assure you it sucked.
Old 05-10-2007, 07:07 PM
JunkyardZ's Avatar
Mine done the same thing, it sucked bad!
If you have some help, then get 1 person on each side of the trans and rock back and forth.lol thats what we did. It will eventually come loose enough to get a flat head screwdriver in between the housing, but be careful and take your time.
good luck!
Old 02-16-2008, 03:14 AM
WaLieN's Avatar
I see you're in Vista! I'm in Vista as well!
Anyways, I've been doing just that for an hour now without any luck. I can get one side off, but I can't get the other side to budge. I've got beer if you have an awesome pry-bar!
But, does anyone have any other ideas?
Old 02-16-2008, 07:55 PM
WaLieN's Avatar
It looks letting the penetrating lube sit over night did the trick.
