STS heat retention
Old 05-05-2007, 05:22 PM
Ironmancan's Avatar
Default STS heat retention
Alright I wanted to see if anyone here that has a STS had coated their pistons, combustion chambers and exhaust.
We, Tom and I (at Tiberio Performance) he's a patient man just ripped mine apart for forging, Bob at Precision has coated everything from the exhaust manifolds to the exhaust side of the turbo housing. Next step when the heads are done is to take them to Bob for combustion chamber and piston coatings. My thought process is that with everything coated it should help with maintaining as much heat/velocity/energy as possible.
I've got the M6 and while I used to get quite a bit of max power. Power off the line was not impressive unless everything was already hot. Something hard to do at the strip. From a roll my car was like a boosted LS1 very strong
Ok boosted compadres have I forgot something? Is there something else I should be doing while I'm in here to get the most out of this package? Has someone already done this and if so what we're your results?
__________________
Old 05-05-2007, 05:57 PM
pdanrichey's Avatar
Wrap the exhaust with that DEI header wrap. It helped a lot on mine.
Old 05-05-2007, 06:01 PM
Ironmancan's Avatar
Even though I got the entire exhaust coated? I'm thinking that would be the same as wrap. No?
Old 05-05-2007, 09:54 PM
GoatChs's Avatar
No...coating definitely helps but does not take the place of the fabric wrap. I'm currently having larger piping fabricated for my STS...it will be coated and wrapped again.
And unless you are running stainless, you want to have your hot side coated before wrapping to prevent it from rusting out...the wrap really holds moisture.
Old 05-06-2007, 06:58 AM
Ironmancan's Avatar
Thanks alot thats what I needed to know. So now that everythings coated, wrap and reinstall. I don't post much here but I read as much as possible. I've been watching your FI posts for a while now thanks
Old 05-06-2007, 07:33 AM
Ironmancan's Avatar
I'm assuming no one has coated pistons and combustion chambers with the STS. Gotta be someone out there thats done it already and can share their results..
Old 05-06-2007, 06:30 PM
Ironmancan's Avatar
bump for the night crew...
Old 05-06-2007, 06:57 PM
BigBenz's Avatar
From a roll my car was like a boosted Supra very strong
__________________
What this mean? I think you should say you car is like a boosted LS1 the nerve.
Old 05-06-2007, 07:02 PM
Ironmancan's Avatar
Lol, I stand corrected and will edit my post accordingly. Damn Noobs
Old 05-06-2007, 11:51 PM
JAvenger007's Avatar
wrap and coating seems to contradict what everyone on here is saying. From what Ive heard and seen, wrapping coated pipe will cause corrosion, rust, and pipe falling apart as well as destruction to the coating. I seems like most guys are getting good results from just porting stock manifolds and wrapping the full exhaust.
Old 05-07-2007, 12:38 AM
99Z28LS1's Avatar
TRT said this would be the best choice if im not mistaken
Old 05-07-2007, 12:05 PM
the coating and wrapping or
just porting and wrapping? Cuz i thought I remembered billy saying to just wrap the stock stuff.
Old 05-07-2007, 03:06 PM
99Z28LS1's Avatar
get the factory manifolds ported and coated and wrapp the stock stuff
Old 05-07-2007, 03:10 PM
LS1Tech Sponsor
Mischievous's Avatar
Tight!!!
Old 05-07-2007, 05:44 PM
pdanrichey's Avatar
Wrapping made an unbelievable difference. Don't discount it.
I personally don't have coated insides on the engine...but I can't imagine that hurting. Sounds like you went all out .
What's done is done...just wrap that nogga and boost freely!
Old 05-07-2007, 07:09 PM
Ironmancan's Avatar
Thanks guys, not discounting it at all I've read good things about wrapping it.
Once everythings back together I'll be taking temp readings/dyno numbers before and after the wrapping. Already got everything coated so there's no going back now. I'll be sure to keep things updated.
Old 05-08-2007, 10:26 AM
Did you guys wrap the manifolds too or just start after the collector?
Old 05-09-2007, 11:36 PM
trtturbo's Avatar
On my own vehicle, I ported the stock manifolds and had them coated. I started wrapping right after the manifolds all the way back to the turbo flange.
Old 05-10-2007, 12:40 PM
ok so theres not much to be gained from wrapping up the whole thing.
Old 05-10-2007, 01:59 PM
Ironmancan's Avatar
I for one don't know. Personnally if i cannot get boost soon enough I'll be hitting things with a little nitrous to get out of the hole. 75/100 shot should work nicely. Don't want to hit it with a two step since I'll be keeping the cats.
Quick Reply: STS heat retention
