Tires
Tires
Well I got rid of my Mickey Thompson ET Street, 26 x 10.5 x 16. I was not hooking up with them at all. Now I bought the 15" x 10 Pro Stars and want to put some M/T slicks on them. What size should I get them 26" or 28" by 10.5 on 3.73's, I'm also pushing 421 RWHP and 400RWTQ. I'm launching around 4500 to 5000 RPM (thats where my peek TQ is at). Oh and I also have all the suspension mods.
i am not an expert on tires and am also going to need some new ones soon. Usually the bigger the diameter the better, no? I am debatting whether to go with torque thrust II 17x11 in the back or pro star 15x11's to fit the m/t's. I got 415rwhp and am curious if some 315 nitto's would hook up good enough or if i have to go for the mickeys.
Originally Posted by ZONES89RS
I say 26", i used the M/T ETs all the time at the track with good results, you must be using them on the street!!!
I think with your power you could pull 28" tires...I'm switching to 4.10s and 28s, but I'm not making the power you are and I'm an A4..My launches on 26" ET radials at last week's track rental were violent and resulted in some spinning to a 1.58...If you are having trouble on 26s then I think 28s would help your launch even with 3.73s...I've seen some good results in stick cars with the 275 60 R15 Et Radials fyi...
--Alan
--Alan
Originally Posted by Speed Density
FWIW,
I had 4.10s and 275/60 MT DRs for my old 396ci, that would probly have put down 450rw.
Tony.
Tony.
--Alan
Thanks guys. I'm gonna get he 28's x 10.5 cause I will be getting the 12 bolt with 4'10 gears and will be doing a cam swap pretty soon (more power). The one time I hooked up with those tires I had to do a John Force burn out, but after that there went the infamous 7.5. I was also able to get the drivers side front tire off the ground like 2" with the stock 17" rims
Originally Posted by 396D1SS
if its a track only tire get a pair of mt et drags 26x10.50S it will allow the wall to wrinkle and take thats sudden "hit" from the 6 speed
I have dead hooked them with a 6k launch on my old setup that was around 650rwhp
