Lingenfelter cam?
Old 05-10-2007, 04:28 AM
LT1Z/28's Avatar
Default Lingenfelter cam?
any one ever run an lpe cam? i found this one 219/219 duration, .560/.560 lift with 1.6 rocker 1200-6200 rpm range. wonder if it be any good? know id need 1.6 rr's new springs and etc.
Old 05-10-2007, 04:57 AM
LT1Z/28's Avatar
seems like it would be a great street cam, wonder how it would compare to the lt4 hotcam?
Old 05-10-2007, 06:35 AM
DroppedM6Z's Avatar
i've only heard good things
Old 05-10-2007, 10:20 AM
96lt1m6's Avatar
virtually any cam is better than the hot cam!trust in LPE that cam works very well.
Old 05-10-2007, 10:46 AM
Pampered-Z's Avatar
I ran the 211/219 for a few years with stage II heads, made 327HP and the car passed smog cleaner then stock. It is a great street cam with plenty of torque around 2,200 to 5,000. It wasn't great for ET as it fell off badly by 5,500.
Old 05-10-2007, 12:24 PM
LT1Z/28's Avatar
thanks guys, im probably going with the 219 now, i keep changing my mind, but ive only heard good things about lpe and figured id ask around and see what yall thought
Old 05-13-2007, 07:51 PM
87Lt1Monte's Avatar
I have to say that i loved this cam.. for alot of street use, i ran 11.9's at the racetrack with 10 bolt and 3kstall. with a little spray i would have been in the high 10's. This was in a 383 factory ported heads.. equivilent to LE2 o guess. Of course im in a G-body weighed like 3400 with me in it. 1.59 60 111mph trap (little low). You will want to change to 1.6 rockers and new springs, i would even change out lifters if they are stock but thats just me.
Old 05-13-2007, 08:37 PM
3pnt4maro's Avatar
the cam i have is very similar 218/218 and its very streetable and nice..i talked to lingenfelter about that cam and they highly recommended it for street manners
Old 05-15-2007, 02:52 PM
Pampered-Z's Avatar
Freind just put his 219 cam up for sale as he's going with a different combination. If you interested, his handle is HardcoreZ28 on WWW.NJFBOA.ORG
Old 05-15-2007, 04:10 PM
ABA383's Avatar
I ran the LPE 211/219 .533/.560 for years in my 383 trapping 115 with high 11's/low 12's....The 219/219 is a terrific street/strip cam with great lift numbers with shorter duration...LT1s love that combo...That was the cam I was going with before I got the Joe O. cam...Call LPE and get the spring package they recommend...If you don't buy the cam used from the forum, get the whole cam/spring package from LPE....
--Alan
Quick Reply: Lingenfelter cam?
