write up on swap???
write up on swap???
hey i have a 95 camaro 3.4 and i need a write up and pics if avalibe of an ls1/ t56 swap ive been searching and i cant seem to find anything can some one please help me. thanks in advanced.
i have an engine and trans from a '99 firehawk. a4 for now, later to be an m6. i'm hoping the k-member, suspension and all will be able to roll out from the firehawk and right under the '94.
that is great you have a parts car, all you have to do is switch it all over, that is the easy part, you will need to get fuel rails for a return fuel system, I would upgrade the fuel pump to a gss340, wiring harness will need to modified so it will plug in
i have 2002 z28 with 6speed full car and im doing brakes as well as tailights and dash swap the wiring is were i need the most help as far as abs or the interior of the dash everything really
