write up on swap???
Old May 12, 2007 | 08:47 AM
95Kyle's Avatar
Default write up on swap???
hey i have a 95 camaro 3.4 and i need a write up and pics if avalibe of an ls1/ t56 swap ive been searching and i cant seem to find anything can some one please help me. thanks in advanced.
Old May 12, 2007 | 07:51 PM
SilverGhost_02's Avatar
i can't tell you anything, cause i wanna do the same thing to a'94 3.4. i'm ANXIOUSLY waiting to see where this thread goes.
regards,
Old May 12, 2007 | 09:34 PM
hpmotorsports's Avatar
i don't have a write up on it ,but i can help you with it, i just put a ls1 auto in my 94 z28.
Old May 12, 2007 | 09:50 PM
95Kyle's Avatar
well tell us what u did?
Old May 13, 2007 | 08:12 AM
do you have a engine yet?
Old May 13, 2007 | 09:33 AM
i have an engine and trans from a '99 firehawk. a4 for now, later to be an m6. i'm hoping the k-member, suspension and all will be able to roll out from the firehawk and right under the '94.
Old May 13, 2007 | 10:04 AM
that is great you have a parts car, all you have to do is switch it all over, that is the easy part, you will need to get fuel rails for a return fuel system, I would upgrade the fuel pump to a gss340, wiring harness will need to modified so it will plug in
Old May 13, 2007 | 12:07 PM
G-Body's Avatar
sawzall wielding director
Either that or run the single line rails that are on the motor and use a vette fuel pressure regulator/filter.
Old May 13, 2007 | 03:39 PM
95Kyle's Avatar
i have 2002 z28 with 6speed full car and im doing brakes as well as tailights and dash swap the wiring is were i need the most help as far as abs or the interior of the dash everything really
