crank bolt
Old 05-12-2007, 09:08 PM
zeekracing's Avatar
Default crank bolt
My crank bolt started stripping out after about the 4th time I took the balancer off. Does any one know that the threads are so I can find another bolt and tap to clean the crank threads?
Old 05-12-2007, 09:50 PM
Jbmoney21's Avatar
Use a ARP bolt the next time.
Old 05-12-2007, 09:55 PM
zeekracing's Avatar
who sells the arp bolt
Old 05-12-2007, 10:09 PM
bad6as's Avatar
can you use an impact gun on the bolt to remove it?
Old 05-12-2007, 10:29 PM
zeekracing's Avatar
yes I was able to remove the bolt.
Old 05-12-2007, 11:49 PM
DONAIMIAN's Avatar
Some do, but its not too bad if you have the right hand tools. I used a 24inch breaker bar and it was no trouble and I weight around 160lbs. Should be easier if your packing more weight.
Old 05-13-2007, 01:06 AM
618HAWK's Avatar
Thread pitch is 16x2.0
I have a brand new tap I can part with if needed, shoot me a PM.
I Would stick to a ARP crank bolt.
Old 05-13-2007, 09:44 AM
zeekracing's Avatar
where did you get the arp crank bolt?
Old 05-13-2007, 10:26 AM
byler900f's Avatar
you can get the arp bolt from thunder racing. i just put one on my car when i did my cam swap and it is alot nicer than the original. It's a hair longer too. the only downside is you need a 27mm 12 point socket. i had to buy one.
Old 05-13-2007, 11:46 AM
bad6as's Avatar
has any one broke a crank bolt off in the crank?
