another "help me pick a cam" thread :) 99 trans am
Old 05-15-2007, 09:20 AM
u lose's Avatar
Default another "help me pick a cam" thread :) 99 trans am
this is not my daily driver. 99 trans am m6 67k on the clock. i am looking for something that will compliment the 918s and is fairly aggressive. looking to make some very good cam only power. does any one recommend a certain cam kit, or just a certian cam to go with the springs i already have? thanks for the help. this board rocks!
MODS
comp 918 valve springs
SPEC 4f clutch (around a 1000miles on it)
hooker long tubes( 500 miles)
custom dual exhaust dumped before the rear(500 miles)
lid
msd wires
few other odds and ends
Old 05-15-2007, 09:26 AM
MPHmotorsports's Avatar
With the 918's being the bottleneck of using more aggressive higher list cams, I would suggest maybe something like a torque 2, F13, or something along those lines.
The XFI/LSX stuff is out the door unless you change springs.
Texas speed sells the Torque 2 which is a 232/234 duration with right at 605 lift.
The F13 is very similar as far as specs go and Futural sells this cam.
Take a look around. I have used a 228/232 cam quite a few times with great results.
Good luck.
Old 05-15-2007, 09:30 AM
u lose's Avatar
can you explian what you mean by "bottleneck"?
thanks for your info. i would love something with a rougher idle sound too.
Old 05-15-2007, 09:38 AM
Well bottleneck as in weak link in your valvetrain IF you were to try and use a faster ramp rate camshaft. Especially something on the LSK lobes. The springs are only rated to 600 lift however I have seen cam's that are 610-615 work with 918's. Not something I would suggest but something that I have seen work.
I personially would switch over to a dual spring kit like the Patroit dual's if I was running anykind of aggressive camshaft. Their springs kit is awsome and is just added insurance. Even if I were running a cam with 590 lift I would perfer the Patroit kit. The cost isn't much but the value is huge. Check them out of your not fimilar with them. They are a sponsor on this site.
Anyways I am not trying to get you to change your whole setup especially if you already have the 918's installed, but if your trying to get into a peak HP cam only setup then the 918's might not be the best choice.
Old 05-15-2007, 09:43 AM
BIG_MIKE2005's Avatar
He means the 918 springs are limiting your cam selection since they are only good to .600 lift.
If you wanna stick with the 918 I'd personally go with a 224 cam. It's not super big, but when you addd some heads with it you'll be over 400 RWHP. Not to mention your under the curve power is gonna be great. This means you won't have to spin the motor as high to get your peak HP. This is great for helpin the stock short block last longer while making great power.
Alot of people under estimate the smaller cams, but they have sent several full weight vechicles into the mid to deep 11's on motor. Peak HP is not always what its about, its also about how you get there. If you wanna go bigger your gonna have to look into a better spring kit & possibly some other mods to go along with it. Just some food for thought.
Old 05-15-2007, 09:55 AM
Big Mike makes some great points. I am assuming your looking for the biggest most peak HP cam out there based on you saying its not your daily driver.
But if your just looking for a nice sounding cam that will add some good power throughout the power band then the 918's can work great.
The cam he suggested is a 224/224 typicially a TR cam, but I believe everyone knows this cam. It has been very popular for years and years and years. What exactly are you looking for out of adding a cam?
Old 05-15-2007, 10:40 AM
maplered ls1's Avatar
IM going with the 228r cam from texas speed will work fine with the 918 springs
Old 05-15-2007, 12:12 PM
u lose's Avatar
i'm looking for cam that gives me good power through out the power band and also provides a nice lopey sound at idle. not my daily driver, but i would like to go with a charger in the future. right now i just want something that will make me somewhere in the 375rwhp and up if possible with what mods i have now.
thanks for all your help. keep it coming!
Old 05-15-2007, 12:41 PM
Get a 224/224 .581/.581 112 from TSP then. It'll work perfect with your springs & the 112 LAS will give you the lope. This cam make solid power through the entire power band, not only top end.
http://www.texas-speed.com/shop/item...d=166&catid=44
Old 05-15-2007, 12:47 PM
u lose's Avatar
what about the patriot 226/226 Dur. @.050 .585"/.585" Lift 112 LSA ?
just want to see what the difference is... just doing some research i've seen people with this cam and the 918's and like the combo. whats your thoughts?
Old 05-15-2007, 12:48 PM
Thats also a good cam & would work fine for your goals & your springs.
Old 05-15-2007, 12:51 PM
u lose's Avatar
anyone know what the powerband is on the patriot? i like the wide band on the tsp!
Old 05-15-2007, 03:41 PM
u lose's Avatar
ok well after doing a little more research i like what the tsp torquer v.2 ... i hearing that the 918s should work pretty well...
any thoughts on that choice?
Old 05-15-2007, 09:35 PM
I think that is a great choice and a well proven cam.
