Do turbo's cause widebands to jump around?
Old 05-15-2007, 09:40 PM
fletchls1's Avatar
Default Do turbo's cause widebands to jump around?
Curious because I just installed mine today and I figured it would only flucuate a little bit but it jumps around quite a bit. My buddy thinks that his may have done the same when he had a turbo kit on his car. I wish I could tell you more of what it was doing but for the short time I was out I managed to have a deer jump on the front side of my car and slide across the hood
But anyways, could anyone just explaine what theirs does so I can compare it to what mine is doing?
BTW- I have the AEM UEGO. Yes the sensor is at a slight angle after the turbo. I currently am running an open downpipe and the sensor is placed about 8 inches from the turbo.
Thanks
Old 05-15-2007, 10:31 PM
Turbo Tech's Avatar
A turbocharger won't cause your a/f to move around. Placement is important. The O2 sensor for the wide band should be placed in the downpipe not the manifold or crossover. Other than that work on your tune up
Old 05-15-2007, 10:39 PM
fletchls1's Avatar
What is the furthest it should fluctuate?
Old 05-16-2007, 12:50 AM
will62085's Avatar
how close is it to your cutout (or where its dumped)? could be reading outside air
Old 05-16-2007, 01:07 AM
Boostaholic's Avatar
Mine jumps all over between 14.5:1 and 11.5:1 depending on what my foot is doing!
Old 05-16-2007, 04:48 AM
fletchls1's Avatar
couple feet
Old 05-16-2007, 04:49 AM
fletchls1's Avatar
How do you tune when it does that?
Old 05-16-2007, 04:57 AM
SStolen's Avatar
Mine is placed 2 ft from my cutout. That shouldn't be a problem though as it is reading the air passing over it. I really don't see how 'outside air' would get to it. The air coming out would be too strong to overcome for it to work its way to it or even mix. Mine doesn't jump around but it will change from 13.5 to 13.6 to 13.7 to 13.6 to 13.7 continuously. It might stay on each value from anywhere from .5 seconds to 2 seconds. Is that what you are talking about? (and that is too rich I know, should be 14.7.)
And I just remebered that my friends car, which is over 1000rwhp only has about 20-22 inches of downpipe before it dumps straight down to the ground. I believe his wideband bung is in the elbow about 12-14 inches from the exit and his car is tuned spot on. So, take that for what you want. Just trying to help. I hate when I have questions like this and no one wants to take the time to answer.
Old 05-16-2007, 05:22 AM
2001WS6Vert's Avatar
It is normal for it to jump around. As you accelerate and decelerate the fuel mixture goes from very rich to very lean at times. Just watch the narrow band sensors with a scanner, they will be all over the place. I think the instructions wanted my sensor to be within three feet of the heads so it would stay hot enough, so I have the bung only on the left side. Does it stabilize as you nail it? If it does it is probably fine.
Old 05-16-2007, 09:47 AM
dixonk's Avatar
I don't have a turbo but mine jumps around like crazy as well. Tune is dead on and it doesn't read even close to the same numbers as the one on the dyno.
Old 05-16-2007, 09:56 AM
6 Second Club Moderator
LASTLS1's Avatar
Mine stays fairly steady, open dumps.
Old 05-16-2007, 10:05 AM
black98ws6ta's Avatar
Believe it or not it is fairly easy for a wideband that is close to the end of the exhaust to get saturated with outside air, especially at low rpms. You could always make a temporary extention pipe if you think this may be happening. Other that that it is normal for the a/f to move around, typically you want it to idle and cruise at 14.7 and then going into boost the mixture should richen up. Some people have the fueling go straight into the 11's even at 1-2 psi, some people have it transfer slowly depending on the application.
Old 05-16-2007, 10:26 AM
SSblack98's Avatar
It is NOT normal for it to jump around more then .5 AFR or so. If it is fluctuating rapidly and more then that something is wrong. My friend had the AEM and had similar issues. Not long after that it was way off. Now he is running a LM1 with no major fluctuation and dead on. Narrow band sensors are supposed to fluctuate rapidly from rich to lean. You cannot apply narrow band characteristics to wide bands. Not the same kind of operation.
Old 05-16-2007, 10:46 AM
RW99's Avatar
Mine varies pretty widely when driving when there is very little throttle applied and the manifold is registering some sort of vacuum. Once I'm into the gas a bit it steps into line around stoich, and when I go WOT it gets to 11.8 pretty quick and stays there. Parked at idle it registers 14.7.
Old 05-16-2007, 12:05 PM
well I turn the data logger on and put my foot in the down position, then watch the AFR
Old 05-16-2007, 12:43 PM
99Z28LS1's Avatar
thats the best way
Old 05-16-2007, 06:42 PM
fletchls1's Avatar
Thanks. Mine changes more than yours. It can jump hole numbers while maintaing a constant speed. Some of its readings have to be impossible. I have seen everything from 10.0 at WOT to 16 at crusing. I am pretty sure it is running rich at higher rpm's so I dont know. I just got this damn thing yesterday and put it in after work. what to do what to do
Old 05-16-2007, 06:47 PM
fletchls1's Avatar
Im trying to learn how to do this so I dont know. You tune your whole rpm range at WOT?
Old 05-16-2007, 07:49 PM
The car shoots for 14:7 at most cruise situations, 11:5 when accelerating heavy, it will go lean when you let off the gas. Actually it does mimic the cars O2 sensors. How do you come up with .5 AFR variation?
Old 05-16-2007, 07:57 PM
fletchls1's Avatar
Would you say it is normal to get anywhere from 14.5 to 15.5 at a cruise not staying on any number but a split second?
Quick Reply: Do turbo's cause widebands to jump around?
