Well, pulled the knock sensors...
Old 05-16-2007, 04:47 PM
whitedevil's Avatar
Default Well, pulled the knock sensors...
Was throwing po327 code, and was getting false knock all over the place, so, I figured it would a good time to install an LS6 intake and change knock sensors. Well, this is what we found inside...
And this was the wire to the rear sensor.....
Anyone have an idea on how the wire did that??? It wasnt touching anything at all. Well, we repaired the wire, installed the new sensors, and the manifold, feels a lot better now. and it isnt flashing 6.9 degrees of knock retard on the interceptors all the time like it was before.
Old 05-16-2007, 05:20 PM
Z28LS1camaroguy's Avatar
could just been rubbing or something like that, but as for your knock sensor it looks like water got in there and corroded it.
Old 05-16-2007, 09:16 PM
nitroracer15's Avatar
the same thing happened to me, water got around my knock sensors, and shorted them out. the rubber boot on top wasn't sealed all the way when the engine was put in
Old 05-17-2007, 11:13 AM
radkon's Avatar
Do you store the car at all? Could a mouse have gotten in there? They love wires and their pee will rust stuff up fast.
Old 05-17-2007, 02:17 PM
whitedevil's Avatar
I dont think a mouse could have gotten between the intake manifold.... I did have to repair a coolant hose due to a "chewed" up looking hole one time.
Old 05-17-2007, 02:27 PM
BigD 275's Avatar
Does anyone have the part number for the knock sensors. I have to change mine as well. Is there just one or two of them? I assume the best place to buy would be gmpartsdirect?
Thanks.
Old 05-17-2007, 02:39 PM
warp10's Avatar
If you can read it off the part...
Old 05-17-2007, 02:44 PM
BigD 275's Avatar
Great, thanks.
Old 05-17-2007, 07:02 PM
whitedevil's Avatar
Bought mine at auto zone....
Old 05-17-2007, 08:01 PM
Mike94ZLT1's Avatar
How much were they? Mine are fine, but I'm putting a new stroker in this weekend and wondering if I should reuse them, or replace them.
Old 05-17-2007, 10:13 PM
whitedevil's Avatar
they were like 42.95 a piece or somthing like that. You'll need two for an LS1...
Old 05-17-2007, 11:20 PM
DONAIMIAN's Avatar
If theyre not rusted, then I wouldnt worry about it.
