Hood Prop Rod?
I used a piece of conduit for a prop rod for a while. It was 1 1/2" round and I set it in the tallest part of the latch on the bottom and the corner of the hood side latch rested in the other end perfectly.
Originally Posted by GETGONE
Then you need less pressure like the shocks used on the SS hoods. SLP should still sell them.
Well I don't know who you talked to but I know on all the Firehawk and SS hoods they went with lighter pressure shocks since they had a ton of take off hood shocks from the heavy steel Z and base Trans Am/Formula hoods that were replaced with the light weight fiberglass/composite hoods.
