is a 383 a inefficient motor?
How so, or was that all you were told?
Now with the low cost of 6Ls and the LQs alot of people feel the bang for buck on LSX 383s is lost. Unlike an old SBC where 383s are kicking cheap and simple.
Originally Posted by SVTlightning87
thats just what they said, im looking at a new Short block and im wondering how much more in the long run it would be to do a 383 or 402
If by "inefficent" you mean "not cost-effective", I would tend to agree. I have a 383 and it is great, but with the marginal cost difference in going up to the larger bore, it is outdated. You have much better heads availible for the bigger bore engines and with the proliferation of the 6.0 the prices are dropping. I bought mine because the price was right and I was pressed for time. If I was to do it over, I'd go aluminum 402+...
i see in the dyno section quite a few 383s that barely out hp a 346 so that may be where they are coming from but the added stroke gains quite a bit of tq and you don't have to spin them to the moon like a 475 hp 346 6700 rpm + to get decent power.just my $.02 though.
LS1TECH Sponsor
its only inefficent if its not a good combo like anything else
it will make more hp than a 346 but not a huge amount just sooner and carry it better , now tq is another story you will gain alot of tq and again come sin sooner and carrys across the bored. ill have my 346-383 numbers next week but just from driving it there's a HUGE tq difference.
like stated above though unless you get a killer deal on a 383 a 402 isnt all that much more and net you even more power an tq .
efficiency
An engine's efficiency is a function of it's compression ratio. Higher compression equals higher efficiency (it puts a higher percentage of heat produced in the chamber into work against the piston). Diesels are the most efficient engines. If you assume 1 lb torque per cubic inch, you get an additional 37 lbs of torque on a 383 vs 346 (that translates to 37 hp at 5250 rpm).
Some engine builders will say that the 383 LS1 engine is not effecient just for the fact that its an oversquare engine meaning more stroke than bore(4.00 stroke, 3.905 bore). I say that its not that simple, IMO the longer the stroke the longer the connecting rods need to be to keep a good stroke to rod ratio. If you take the stock LS1 with its 3.622 stroke and 6.098 rod its got a R/S ratio of 1.68 now take the same engine and stroke it to 4.00 and then youve lost alot going to 1.52. The more ratio you have the less angle you have on the crank at mid stroke for more direct/straightline path of leverage to turn it. So this is why I like building LS1 strokers with 6.200 rods since they have a R/S ratio of 1.55, which IMO is the minimum ratio to run in a performance engine. Now on the bore, the bigger the bore the less shrouded the valves will be so they can breath...as long as the cylinder head has been worked to take advantage of a large bore.
