No Lights!!!
Old 05-20-2007, 04:18 PM
RICEBURNER's Avatar
Question No Lights!!!
So i got into my car the other night and realized that my fog lights and aux tail and side lights were not turning on when i flipped the switch but my headlights came up and worked, and the turn signals blinked as well as the brake lights commin on but none of the running lights work...and the lights behind my gauge cluster and hvac also do not turn on or anything! anyone know what went wrong?!?!? please help!!!
Old 05-20-2007, 04:21 PM
dragonrage's Avatar
Fuse?
Old 05-20-2007, 07:19 PM
Ungrounded Moderator
WhiteBird00's Avatar
Replace your TAIL LPS fuse.
Old 05-20-2007, 11:01 PM
Copy & Paste Moderator
VIP1's Avatar
Wouldn't that mean that his taillights wouldn't work either?
Does the CHMSL use a different fuse?
Old 05-21-2007, 12:41 AM
RICEBURNER's Avatar
what is the CHMSL? and the brake lights work (second stage of the bulb) just not the first stage/running lights
Old 05-21-2007, 12:45 AM
VIP1's Avatar
C - Center
H - High
M - Mount
S - Stop
L - Lamp
Its the third/center brake light.
Old 05-21-2007, 08:07 AM
He said his tail lights (running lights) weren't working. The TAIL LPS fuse is somewhat mislabeled - RUNNING LPS would be a better description. It protects all of the running lights including the tail lights, license lights, side marker lights, fog lights, and front running lights as well as the dash lights through the IP DIMMER fuse. It doesn't connect to the brake light, turn signal, or hazard flasher circuits so those would be unaffected.
Old 05-22-2007, 12:52 AM
RICEBURNER's Avatar
well, it was not the IP DIMMMER fuse but the TAIL LPS fuse...replaced it ant horay it works! thanks for the help though guys!!! i can drive her at night again!!! :-D
Old 05-22-2007, 10:47 AM
VIP1's Avatar
What Whitebird00 meant is that the IP DIMMER fuse gets its power from the TAIL LPS fuse. So if the TAIL LPS fuse is blown, there will be no power at the IP DIMMER fuse.
