Can you reuse stock main bolts?
Old 05-20-2007, 08:58 PM
02Z28's Avatar
Default Can you reuse stock main bolts?
Or do I have to replace them?
Old 05-20-2007, 09:10 PM
Tainted's Avatar
I *think* you can re-use them but dont hold me to it.
Old 05-20-2007, 11:32 PM
chriswtx's Avatar
They can be reused...
Old 05-21-2007, 06:24 PM
02Z28's Avatar
Anyone know the torque specs?
Old 05-21-2007, 06:27 PM
LSXNV's Avatar
since you have the engine apart, you might wanna consider studs. i dont know the price on LS1's but the were an ok price for a little insurance.
Old 05-21-2007, 06:28 PM
87gnx's Avatar
If they aren't stretch or(torque to yield) bolts they may be used again idk.
Old 05-21-2007, 06:35 PM
Moderator
davered00ss's Avatar
Why would you want to. While you have it apart use good bolts. ARP or the KaTech rod bolts. I don't believe they were meant to be reused.
Old 05-21-2007, 06:45 PM
crainholio's Avatar
You're building an engine and popping a few bucks for a manual is out of the question? So much good info in there...bearing clearances, torque specs and sequences, etc. Tools aren't exactly where you want to do your cost-cutting, and a good manual is exactly that.
Old 05-22-2007, 06:31 PM
02Z28's Avatar
I have a manual buddy! Just don't have it in front of me right now, so I figured I would ask you guys on here. I'm just trying to figure out my options. I've read that the stock main bolts are good for around 750 HP. Thats plenty for me. I know I can buy ARP's but if I don't have to I don't want to. My plans are to run this motor until the end of the year, then build a bigger one. So why dump a bunch of money in it if I don't have to.
Old 05-22-2007, 06:32 PM
02Z28's Avatar
If I put studs in it, don't I have to get it line honed?
Old 05-22-2007, 07:03 PM
chriswtx's Avatar
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees
Crankshaft Bearing Cap Side Bolts 18 lb ft
I went through this deciding on parts for my blower motor..All the top shops said ARP main studs were a waste on anything under 800RWHP... Just finished assembling my motor stock main bolts, ARP head studs...
Yes you should but most don't and get away with it..
Old 05-22-2007, 07:10 PM
02Z28's Avatar
Awsome! Thanks a lot man.
Old 05-22-2007, 07:12 PM
chriswtx's Avatar
If you need any more torque specs www.ls1howto.com has them at the top of the page...
Old 08-05-2007, 12:02 AM
yobabiesdaddy2001's Avatar
did you reuse your old main bolts, if not where can you get a new set?
Old 08-05-2007, 07:53 AM
JimMueller's Avatar
12560273 GM crankshaft stud
12560272 GM crankshaft bearing cap bolt
12556127 GM crankshaft bearing cap bolt (side)
10 bolts each, I paid $70 total for all of them through a non-sponsor internet dealer.
Old 08-05-2007, 12:27 PM
02Z28's Avatar
I re-used mine... no problems so far.
Old 08-05-2007, 12:28 PM
how long has it been since he rebuild?
Old 08-05-2007, 12:42 PM
pist0lpete's Avatar
You should in no way ever re-use the inner torque to yield bolts. They are a one time use only. The outer cross bolts are not torque to yield and can be re-used however. Use the part numbers above and get yourself a set.
Old 08-05-2007, 12:44 PM
from where, who can get em?
Old 08-05-2007, 01:19 PM
that part number above says that they are for a l92 in Spdc catalog
Quick Reply: Can you reuse stock main bolts?
