Shortening the length of the stock A4 Automatic Shifter????
Wondering if anyone has done this in their camaro. I think it would look cleaner with the **** closer to the gate. thanks and post pics if you have any
Are there any aftermarket ***** you can put on that make it look, not so.. bleh? My leather is starting to fade on it... the only thing in the car that is fading.. bleh
Copy & Paste Moderator
Shorter shifter & aftermarket ****:
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
Other aftermarket *****:
https://ls1tech.com/forums/appearance-detailing/476760-automatic-shift-knob-conversion-kits.html
https://ls1tech.com/forums/appearance-detailing/510891-auto-shift-knob-options.html
https://ls1tech.com/forums/appearance-detailing/507571-auto-knob.html
https://ls1tech.com/forums/appearance-detailing/474757-retro-shift-knob-auto.html
https://ls1tech.com/forums/showthrea...&page=11&pp=20
https://ls1tech.com/forums/showthrea...&page=17&pp=20
Here is how I added a shift boot to my A4:
http://www.fadingarrow.com/ShiftBoot.htm
Readline Goods also sells leather shift and e-brake boots.
Originally Posted by Ls1CamaroGuy87
Did you reinstall that little clip shaped like a U? And how did you cut the metal without hitting the white plastic on the inside of it?
I used a small cutting wheel and dremel and cut it exactly how it looked like before. Except an inch shorter.
Originally Posted by Brian2006
Shortened mine also. Let me know if you need help doing it:
Before:
During:
After:
Before:
During:
After:
looking good! I was thinking of making the bottom of the **** flush with the gate or a 1/4" above it. not sure if that is too low or not? thanks for the pics and everyone else who posted info!
