Who knows how to remove taillights on TA?
Just like the thread title states- I did some seaching and didnt come up with anything. How do you remove the stock honeycomb tail lights on a TA?? I got some LED's for my reverse lights and I dont know how to get the lights off. Any help would be nice. Thanks in advance.
Open hatch, remove cargo hatch cover, remove both left and right side plastic panels that house your hatch speakers, remove the carpeting from the rear face of the hatch, you'll then see numerous plastic wing nuts that hold both the center filler panel and the tailight housings in. You need to remove the center filler panel first, then you will be able to remove the tailights by removing those wing nuts. I think there is also a small 10mm nut that needs to be removed on the outermost corners of each TL housing - closest to fenders.
When replacing - install both TL first, but leave tailight housing wing nuts loose. Then install center filler panel and tighten it down, then align TL housings so gap is even all way around and tighten their wing nuts/bolt.
Replace carpeting and plastic panels - done!
-Jay-
-Jay-
Copy & Paste Moderator
-Jay-
-Jay-
* The center filler panel has a lip on either side behind the taillights so it is removed after the taillights and to goes back on before the taillights. If I remember correctly, the inner two most wing nuts from each taillight also hold on the center filler panel.
* There are no extra nuts/bolts. Only the large plastic wing nuts.
,,then,,when you go to put it back together,,,be very careful with the plastic wing nuts,,they strip out very easy. If you encounter this issue, go to your local hardware store and buy some U shaped machine screw nuts....they do not look like nuts but rather black flat folded lookin piece of metal, with a hole in it. The size is 1/4-20. i ran into this problem when i installed my amp rack. I've heard some of people using wood with a smaller hole drilled in it, then threading it on to the bolt,,,,,i chose the other method for acleaner look,,,under my carpet.
