question about a ticking sound
ok i have this ticking sound it comes from the left driver side of the engine. it is not present if the car is park and it doesnt tick if i rev the motor up from a stop. i did notice a little bit of lost oil pressure when the car has been running for a little while. heres a video of it. http://youtube.com/watch?v=dK_fQ_5NSNw . any one got a idea?
well yea there is a slight exhaust leak but the ticking noise is not the sound that you hear on that clip. see some say it could be a lifter but i was also seeing what else it might be.
Holy cow!!! if it sounds that loud in the car I could only imagine outside. you need to stop driving it and figure out if it's a spun bearing ot collapsed lifter. that sound like a knock not a tap, could be a loud tap which then I would look at lifters if kinda of a knocking sound then probably spun bearing... man I feel it!!!!
cowboy chill trust me its not a spun bearing. because if you didnt read i said its in the top end not the bottom end. and who said im driving the car any more. you are getting aheado of you're self here
you say rattle i say tick thats just how i described the sound. but i wanna know why it would only make it while i drive the car. and not while the car is parked like if its parked and i rev the motor it dont make a sound. i put it on a lift and and put it in gear and gave it some gas still no sound only while the car is moving does it make the sound. like would the increase load of the car pulling its weight cause a sound to come out in the top end?
Originally Posted by fuseone
yea thats what i was asking and what could cause a ticking sound in the head only when there is a load put on a car while moving?
was listening to vid and noticed the "sound" kinda goes away there at the end then comes back before vid ends, are you shifting gears at that point or just letting of the gas pedal? is it an M6 or A4?
