Is this bad? *pic*
Old 05-24-2007, 04:29 PM
93BlackZ28's Avatar
Default Is this bad? *pic*
Not to sure what it is, but its kinda liquidy. Anyone know?
Old 05-24-2007, 04:58 PM
Sharpe's Avatar
What the hell? I don't know.
Old 05-24-2007, 05:31 PM
unSStoppable's Avatar
uhh i dunno?
Old 05-24-2007, 05:33 PM
05_Gunmetal_Silv's Avatar
What the heck did you run over?
I have no idea but it doesn't look like it's good...
CARTEK Racing
WS6TransAm01's Avatar
looks like old tranny fluid that made its way up though the grease that is packed into the center of the Pro 5.0 shifter.
It should not have happened because there is usually almost now fluid in the shifter linkage compartment but I would not worry to much about it.
Did you recently fill the trans with fluid? Maybe overfilled?
Old 05-24-2007, 05:39 PM
Sharpe's Avatar
Why is it gray, though? That grease is yellow.
Old 05-24-2007, 05:57 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Graphite based grease such as anti seeze has that look.
Old 05-24-2007, 06:45 PM
Jimmard's Avatar
Mine looks similar to that
Old 05-24-2007, 06:57 PM
93BlackZ28's Avatar
I have not done anything with the tranny since ive bought it except put the pro 5.0 shifter on.
Old 05-24-2007, 08:07 PM
Mike44138's Avatar
Looks like somethings making metal and it's mixing with either the shifter grease or tranny fluid. If you're really worried clean it, change the trans fluid and see what condition it's in. If it's not obviously full of metal don't worry bout it.
Old 05-24-2007, 10:17 PM
Kalgorn's Avatar
Mine is similar but nowhere near that bad. How long have you been running the shifter? I've only had mine in since the first week of January. It's not the tranny fluid either because I changed that over to Syncromesh around the same time.
Old 05-24-2007, 10:46 PM
nd4spd22's Avatar
I put mine back together tonite... It looked similar to yours. It was just grey grease. I cleaned mine up and put some different grease in there and no problems.
Old 05-27-2007, 10:37 AM
TLUZLS1's Avatar
Same thoughts here. Ive never seen or heard of anything like that.
Quick Reply: Is this bad? *pic*
