Generation III Internal Engine - lunati / eagle stroker kit differences
jsconiers
05-25-2007, 04:29 AM
Can some one please clarify what the differences are between a Lunati and Eagle Stroker kit are? I've read there was a difference in connecting rods (I-vs-H) and the need of a crank trigger. Is this correct?
along with lunati is stronger and alot lighter in rotating mass
your comparing top of line to budget
jsconiers
05-26-2007, 08:14 AM
OK....does eagle require a crank trigger or anything special? Or is it that its a chap version of the Lunati.
Grimes
05-26-2007, 12:37 PM
the eagle will come with the crank trigger as well. some say the eagle cranks require more balancing. alot of ppl here have used eagle stuff with no problems.
Eagle may pose a problem if you have an M6. Pilot bearing doesn't fit as snug as it should.
jsconiers
05-26-2007, 04:51 PM
OK, I'm going with an A4 so that shouldn't be a problem. I thought there would be a larger difference to support the large jump in price. You know...parts included, strength, performance, etc,
Grimes
05-26-2007, 06:11 PM
I think that was a problem with a small number a while ago....but yeah,it is something to look out for.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
