Considering Cometic .040 gaskets...Shoudl I?
I'll be getting TSP H/C with a ported Fast 90. The 228r cam for sure with the LS6 heads I think. Now why would I want cometic .040 head gaskets over the regular GM ones. I guess it raises compression which = more power/torque?
If I got the 5.3 heads, I'd do stock gaskets. This brings me to this question: What heads would be better for my setup?? LS6's or the 5.3's? Maybe this should be another post?
Moderator
I went with a stock Gm gasket because I had trouble getting the cometic's to seal in the past. Cometics will give better "Quench" which will = more HP and guard against detonation.
As for the heads, I would go AFR's milled to bump compression. ( not sure how much you can mill with that cam. If I were to go other than the AFR's second choice would be the Patriot performance LS6 heads. They seem to do better than the TSP heads I have seen.
