Squeeling/tapping in valvetrain
Old 05-25-2007, 08:30 PM
theblur98ss's Avatar
Default Squeeling/tapping in valvetrain
The other day I started getting a squealing noise in my passenger side valvetrain. I relashed all the valves but it's still there. I also noticed it's tapping alot more. Everything seemed normal when I was in there. I plan to pull the rockers and go from there. Is there anything I should be looking for or something that could cause this?
Old 05-25-2007, 08:32 PM
Tainted's Avatar
can you describe the noises a bit better? does it go up or down under throttle?
Old 05-25-2007, 08:37 PM
DONAIMIAN's Avatar
Check your oil for metal shavings. Could be a turned lifter, but thats worst case.
Old 05-25-2007, 09:19 PM
It comes and goes with rpm's if that makes sense. The higher the rpm the more frequent and quicker the noise is....almost like something rubbing. When it first started it only did it when the car was up to temp. Now it's all the time.
Old 05-25-2007, 10:54 PM
frtupchevy's Avatar
Your describing it like more of a rubbing. Then i would say more along the lines of accesory drive (alti, idler, p.s.)?? sounds can be decieving. Try a dab a grease on the belt. I have heard belt glaze make a tap/rub noise.
Old 05-26-2007, 07:34 AM
Moderator
davered00ss's Avatar
could be your ideler pullies.
Old 05-26-2007, 01:16 PM
Maybe I'll take the belt off and start the car to see if the sound is still there.
Old 05-27-2007, 04:50 AM
DaddySS's Avatar
When I had that noise it was bad cam lobes chewing up lifters. I would check the oil for debris right away.
