427ci trubo cam??
427ci trubo cam??
search won't cooperate...are there any good 427 turbo cams out there or will i have to go custom???
15psi - DD/road racer so it needs to be a pretty streetable cam. one guy already suggested the ls7 cam, i'm inclined to agree unless anyone know of anything better.
thanx
thanx
well i'm planning on using the APS twin turbo system, 4.125" darton sleeves and a lunati 427 rotating assembly (10.6:1 cr), ARF mongoose heads (72cc combustion chamber, 225cc version), cam undecided obviously, valve train also undecided (can't do all that until you pick the cam right), fast 90/90, all the other bolt ons except exhaust - the APS system takes care of the manifolds back to the cats more or less and i'll drop in a three inch exhaust from the cats back with twin cutsouts.
if you want more specifics i'll be happy to oblige
