Won't go into 3rd at high RPM?
Old 05-26-2007, 07:10 PM
Moderator
davered00ss's Avatar
Default Won't go into 3rd at high RPM?
Took my car to the track and shifted 1-2 fine. Went to go into 3rd and would not go. Tried 4th same thing. Car is fine on the road, just not at 6500RPM at the track. Tried 2 passes and the same thing both times. Still beat my friend's new 07 GT. 2nd and coast to the traps.
Old 05-26-2007, 09:08 PM
todds69's Avatar
sounds like you and me are in the some boat.
Old 05-27-2007, 12:31 AM
hotrod18_69's Avatar
Sounds like the slave is crapping out...
Old 05-27-2007, 05:54 AM
BigKap94z's Avatar
My car does almost the same thing, but the when i launch the clutch goes half way to the floor and stays there. The 1-2 shift is fine, just slightly delayed but the 2-3 is very slow and hard to get into gear. My slave was replaced when i replaced my clutch about 3k miles ago. Does anyone think the drill mod/master cylinder replacement will fix this problem?
Old 05-27-2007, 06:37 AM
Moderator
Clutch is a new SPEC 3+ w/Billet flywheel. Slave is upgraded 02 Slave/master put in about 2 years ago.
Old 05-27-2007, 09:30 AM
BigKap94z's Avatar
Do you have the drill mod done?
Old 05-27-2007, 09:56 AM
Moderator
thechef's Avatar
Dave i got the same clutch SPEC 3+ and i just got 500 miles on it and i went to the track friday and i am having the same problems at high rpms, let me know what ya figure out
Old 05-27-2007, 10:34 AM
Moderator
I think it's the tranny. Should have had Don rebuild it while it was out for the clutch.
Old 05-27-2007, 10:43 AM
Moderator
thechef's Avatar
yea i am hoping mine is a tired tranny to mine has 90k miles on it
but the clutch held great and i was able to pull the wheels on the launches i just couldnt make a full pass without 3rd gear
Old 05-27-2007, 10:56 AM
Moderator
What did you run? I ran a 13.2 @ 80 putting it in neutral after 2nd. Still beat the GT I was racing.
Old 05-27-2007, 11:06 PM
MY99TAWS6's Avatar
I had the problem of 3rd especially at high rpm .I tried like five different shifters,different tranny fluid and finally the drill mod. The drill mod works. Pain in the butt but do it. Its a lot easier when master is out of the car.
Just do it.
Old 05-28-2007, 05:28 AM
LS1Tech Sponsor
Slowhawk's Avatar
Could be burnt hydrolic fluid but it sounds like a bent/broken 3rd/4th clutch fork.I can do those in my sleep.
Old 05-28-2007, 12:44 PM
Moderator
So how much to fix it?
Old 05-28-2007, 01:07 PM
FU_I_AM_UltraZ's Avatar
maybe you're just not hitting 3rd right? do you still have the stock shifter and handle?
Old 05-28-2007, 03:16 PM
Moderator
UMI short stick on a Hurst shifter. Never had this problem before. 100 or so passes on the car. Only 3 last year & 2 this year. Looks like I'm done for the year now.
Old 05-28-2007, 05:31 PM
Figz Z28's Avatar
We had a same prob a while back it ended up being the springs on the clutch, and would not let the clutch fully engage. But like mentioned above id check the forks.
Old 05-28-2007, 09:15 PM
todds69's Avatar
i was having the same problem not going into third at high rpm i just got done doing the drill mod and it fixed my problem.i'm glad it worked too cause i just had the trans gone through less than 2 weeks ago,glad i don't have to pull it again.now it goes into third like a champ.
Old 05-29-2007, 01:07 PM
LS1TECH Sponsor
BAGN's Avatar
What size drill bit did you use?
Thanks
Old 05-29-2007, 02:22 PM
LS1TECH Sponsor
badpewter-z's Avatar
dave thats exactly what mine was doing the end of last year. new forks, sliders, syncros and a destroyed 5th gear its time for a rebuild . don knows what ya need im sure . it sucks but kinda just maintance when ya beat theses trannys with the stock forks and sliders
Old 05-29-2007, 05:34 PM
onecamaro1's Avatar
Ok, i had the exact same issues and just did the drill mod right now. Man!!!!!!!!!!!!!!!!!!! its the shiznit! I went and took it to 6500 in 2nd 3 times to make sure and it shifts like its sitting still. You gotta try it!
Quick Reply: Won't go into 3rd at high RPM?
